Sponsored by: Sake Bomb
rear upper A-arm affect alignment?
Old Feb 6, 2010 | 08:02 AM
dan_uk's Avatar
Default rear upper A-arm affect alignment?
I've got a torn bushing boot on a rear upper a-arm I have an arm with a good bushing I can swap it out with b4 I hit the track
I don't want to do it right now if I'm gonna have to get an alignment it doesn't look like it'd affect alignment?
Old Feb 7, 2010 | 03:04 AM
SpitfireS's Avatar
You mean the ball-joint boot?
With the wire-circlip?
As long as the ball joint is straight alignment would be the same.
If the ball joint is bend without you knowing it, it may change alignment.
edit: I would just swap the boot, not the whole arm IF that is what you mean.
Old Feb 7, 2010 | 11:39 AM
macr88's Avatar
There is a bit of play on the two bolts but I think it might be very minor. I've removed the upper arms and put them back on before with no real difference in alignment specs.
muha22752
Aug 24, 2012 02:10 PM
EK9MAX
Aug 9, 2010 06:25 AM
dan_uk
Feb 6, 2010 05:16 PM
