Sponsored by: Sake Bomb
Sagging Spring
Old Feb 23, 2011 | 10:27 AM
adamdweck's Avatar
Default Sagging Spring
My front left wheel is sitting higher in the wheel well. Checked the suspension and all looks good, so assuming it's gotta be a weak spring. I was looking into aftermarket springs but all lower the car. Normally I wouldn't mind but I drive in NY where the roads are terrible and scrape the front a lot as it is so don't want to lower the car anymore. Also don't want to stiffen the suspension for the same reason. Can anyone recommend a spring set-up? Or should I just go OEM. And if so does anyone have a fresh set of front OEM springs they are looking to get rid of?
Old Feb 23, 2011 | 11:08 AM
whiteflash's Avatar
I highly doubt your spring is sagging, I'd be willing to bet it's your shock.
There's a marketplace, and your local for sale thread if you're looking to buy.
Old Feb 23, 2011 | 12:38 PM
CU03BLKS2K's Avatar
The ground control springs can be made to oem or koni yellow shock spec, and you can adjust the height. I haven't tested it at it's highest point, but I would guess it's at least as high as stock.
Old Feb 23, 2011 | 12:42 PM
it'S2klean's Avatar
Don't buy aftermarket springs if you don't want to lower the car...our suspension is built to work with our springs so if you swap them out your gunna loose some handling, and this is quoting from the suspension thread. Springs are basically the cheap way to lower your car, if you like your height, dont go with aftermarket springs.
plus this should get a pop over to suspension forum soon enough.
Xene
May 17, 2012 06:57 AM
stockae92
Sep 10, 2009 08:49 PM
Pierre S2K
Sep 15, 2008 12:05 AM
Xplosiv
Aug 21, 2003 10:47 PM
