Sponsored by: Sake Bomb
stoptech brakes
Old Jan 3, 2020 | 12:56 PM
02s2ki's Avatar
Default stoptech brakes
Question: i been seeing s2k has rear BBk from stoptech has ebrake.... but meanwhile when i call they dont make one. they used the one of NSX? thank you
Old Jan 4, 2020 | 12:07 PM
Feezy's Avatar
The kit with the external rear e-brake is a Trophy kit iirc. It's also sized for an 18in wheel, as the rotor is a larger size than the one they run on the fronts for the 17in Trophy kit. There was a guy who stuffed the rear kit under a set of 17in CE's but he had to physically grind down the outter edges of the rear e-brake caliper to make it fit.
If they would just put together a similar kit that fit under 17's I'd buy it today.
Old Jan 5, 2020 | 10:52 AM
Bullwings's Avatar
Same, even though the only time I ever use my hand/e-brake is when I put the car on jack stands...
sjt
Feb 9, 2020 06:41 PM
Mr._ap1
Aug 22, 2018 12:19 PM
galbi_jjim
Aug 14, 2018 05:01 AM
kjonesy203
Jul 7, 2018 11:39 AM
boltonblue
Jun 7, 2017 04:02 PM
