Sponsored by: Sake Bomb
Swaybar conversion
Old Sep 9, 2013 | 09:09 AM
zappatilla's Avatar
Default Swaybar conversion
I have S2000 02 and i just bought a CR suspension to go faster on the track, taking into account the specifications of hardness of the swaybar,would you change the swaybar 2002 by CR? Would it be enough to change just the front swaybar?
| Front Rear | Front Rear
Model Year | Spring Spring | Sway Bar Sway Bar
2000-2001 | 219 291 | 393 427
2002-2003 | 246 309 | 300 396
2004-2005 | 262 278 | 300 311
2006-2007 | 262 269 | 300 311
2008-2009 | 280 294 | 354 311
2008-2009 CR | 384 343 | 392 362
Note 1: All figures are in lb/in. Divide by 56 to get kg/mm.
Old Oct 1, 2013 | 06:43 PM
S2000_Europe's Avatar
hola Zappatilla
I had and S2000 in Spain. I used the CR suspension with Cuzco 28 mm swaybar but I also wear 255 all around and a CR wing and no rear Sway bar.
IF I remember well ap1 swaybar where thicker than AP2's. Have to check the CR sway bar diameter
Old Oct 1, 2013 | 07:14 PM
Vanishing Point's Avatar
Here are the CR spec's for the springs and sway bars, hope it helps.
Front Springs: 51401-S2A-S21
Honda Color Coding: Blue Yellow Orange
Spring Rate: 391 in/lbs or 7.0 kg/mm (Base S2000 4.75 kg/mm) (Thanks Mchester)
Free Length: 9.89in
Rear Springs: 52441-S2A-S21
Honda Color Coding: Blue Orange Orange
Spring Rate: 346 in/lbs or 6.2 kg/mm (Base S2000 4.88 kg/mm) (Thanks Mchester)
Free Length: 10.13in
Front Sway bar: 51300-S2A-S11
Diameter: 28.6mm
Thickness: 4.5mm
Measured Spring Rate: 392 lb/in
Rear Sway bar: 52300-S2A-S01
Diameter: 26.5
Thickness: 4.5
Measured Spring Rate: 362 lb/in
Source: http://www.mccanless...prings_rev1.pdf (John McCanless aka twohoos)
Jah2000
Dec 12, 2015 08:26 AM
jean-roch
Jan 14, 2013 02:58 AM
jooboo
Sep 11, 2011 06:21 PM
hypforlife32
Jun 1, 2011 12:16 PM
