Swift or Eibach springs?
Originally Posted by s2000Junky' timestamp='1436420817' post='23674720
Swifts are more compliant for a give
This is because different alloys have different yield strengths. The hire the yield strength the more the spring can flex before it deforms plasticly (like bending a paper clip too much). Hypercoil and Swift appear to use thinner wires and fewer coils for a specific rate and length. That makes them lighter and allows them to compress more. For an 8" 2.5" diameter 10k spring that may be 4.7" vs. 5.1". However, because there is less metal, it is slightly lighter. Nothing anyone would notice unless you are in a race were hundredths of a second count.
Swift, Hypercoil, and Eibach all make top quality springs and are widely used in racing. There are lots of other spring manufacturers (e.g. Afco, Integra, etc.) plus really cheap imports. Some of these many undergo high cycle fatigue. 20 years ago it was very common to check those coil springs regularly for rate (the rate goes down as they fatigue). Not as much any more. If you look at the various racing tool providers a coil spring tester is a pretty common tool.
Sidebar: The modulus of elasticity is also known as Young's Modulus after Thomas Young who wrote about in 1807. Young was involved in lots of things and was heavily involved in deciphering the Rosetta Stone, itself discovered in 1799 to understand Egyptian hieroglyphics.
Ride is impacted by the shock and the spring. A good shock can make a fairly big difference.
The Koni fit a need for a rebuildable, adjustable shocks at a low cost. Times have changed and there are several decent rebuildable monotube shocks also at relatively low prices. There are lots of threads on the topic. Two recent ones are Bilstein PSS9 -vs- HKS GT IV and Battle of the $1200 coilover! . You may also find My Fortune Auto 510 series review, Fortune Auto 510 - Spring Rate & Valving Opinions, Fortune Auto 500 Series Coilover Review, Ohlins DFV and Urge review, Ohlins DFV's installed , and HKS Hipermax iv GT coilovers interesting.
To add, improved spring response (to bumps) was specifically my term for compliance. 10k 14k etc is just that on a static load, but we aren't talking anything static when referring to a working suspension when ride/handing is the concern.
I hate to hear about the hobbies your actually passionate about
Compliant would mean softer...not more travel. They are not more compliant. http://www.oxforddictionaries.com/us...lish/compliant
Originally Posted by ES2K' timestamp='1436831894' post='23679503
Thanks to all for your input.
I currently have swift spec r springs on my 06 ap2. Even though the lowered height of the car is spot on perfect I wouldn't put Swifts on ap2 shocks again. My ride is softer that stock but has a pogo stick effect that it didn't have before so it's bouncy over big bumps n dips. I've had them for about a year and the tide has gotten softer but I say it's the shocks getting older and not the springs since Swifts don't settle from what I've read. If I could do it all over again I'd get either cr shocks or koni shocks w the Swifts and not ap2 shocks.
The Swift Spec-R springs for the the S2000 are 7.5/7 (420#/390#), a bit stiffer than the CR. And they lower the car 1.2" which must have an impact on roll centers. Also note that most springs can be plus or minus several percent...enough that in this case the rears could be as stiff as the fronts.
It is very possible they are a bit much for the stock shocks, especially if the stock shocks were worn.
Mr. Junky, you have springs and shocks confused. They usually move in parallel because a stiffer shock is need to control a stiffer spring. However, the forces responding to road irregularities and initial body movements in response to steering, braking, and throttle inputs are overwhelmingly from the shocks.
Really, the thread should have said:
1) There is no functional difference between the different brand of springs that will affect an S2000. The spring selected should be tall enough that it has enough travel never to coil bind or go out of its operating range.
2) All of the shocks have roughly the same travel. The issue will be how much the car is lowered, taking away bump travel. Many aftermarket setups start with 1" or more of lowering, taking away bump travel. Most of the time, this isn't noticed
3) Going from a monotube to a twin tube shock is a step backwards. The only reason it has been done was go to stiffer springs on a budget; I don't think anyone is saying let me trade my Ohlins, Penskes, etc for a twin-tube Koni. There are also some lower cost monotubes these days and a complete Ohlins kit, the DFV, which includes shocks, 10k/8k Eibach springs (but painted yellow), and tophats for $2450. It is possible to get an HKS or Fortune Auto monotube in the $1200-$1800 with springs. Swift springs are an option on the Fortune packages. There are numerous threads where people are happy with all of them...however few people have ever driven more than one of them.
4) Note that any of these will move you out of the Street autocross classes.
Note that Koni lists an 2812 monotube for the S2000...it seems to sell for $1000/shock but can'f find anyone actually using them. They are a bit of an odd design with separate pistons for bump and rebound and the shaft adjustment appears to change the preload on the shim stack. No base valve (note: an adjustable reservoir is also a base valve).
My guess is you'd find the Ohlins DFV, FA 500 or 510, or the HKS ok. The HKS is made in Japan and has two versions: an SP with 16/16 springs you'd probably find too stiff, and an SP with 8/7 springs which you might find too small a change from stock. FA custom assembles the shocks in Virginia to whatever springs you decide on. They are in 'generation 5'. And they are the least expensive. Ohlins is a major name in racing shocks, and the DFV is a high quality assembly. It comes with a 10/8 springs which seem to work well on the street. I'm not sure what rebuild revalve service HKS offers in the US. Fortune can rebuild their shocks to any valving and there are Ohlins dealers (e.g. Urge a sponsor, and PSI) who can revalve the DFV. Pricewise, the DFV is its best value if used as it came in the box, sorted by Ohlins as part of their Road and Track collection.
Depending on how frequently you want to change tires you could also go to more aggressive tires. The Michelin PSS are probably the best performance street tire available. However, the Bridgestone RE71r is a race tire pretending to be a street tire. I'd recommend staying with the Michelin PSS for a street only daily driver.
Also, the S2000 US alignment spec has very little front camber. Realigning for more front camber may help response. Autocrossers use as much as they can get, usually limited by the chassis adjustment range to -1.9°. Be forewarned: some S2000s have their adjustment bolts frozen, especially the caster adjustment. My car had one caster adjustment frozen so I ended up with -1.7°. Factory rear spec is -1.5°.
I'm not as familiar with Swift springs, but I've had some great experiences with the Eibachs. They've been around a while and have a proven track record.
http://store.excelerateperformance.c...0/i-53649.aspx
You guys have given me a lot of great info here.
I have one further question though regarding how long aftermarket shocks will last.
For the last few years I've settled on (for an AP1 and an AP2 I have), Swift SpecR springs paired with CR shocks. Literally transformed the handling vs standard AP1/AP2. I've gone with the Swift springs instead of CR springs primarily to lower the car a bit. They are about 9-14% stiffer than CR springs.
It's my daily driver (25,000 freeway miles a year), and I do about 6-10 track days per year. Not much autocross anymore. I use tires such as BFG Rivals, Bridgestone RE-71r, Dunlop StarSpecII, etc. I want the best performance I can get without completely breaking my budget over the long run. In the past I've used used CR shocks, with 9,000-20,000 miles when I buy them.
Question: I've wanted to go to an aftermarket shock if it would offer me as good as or better performance than the CR shocks. CR shocks have satisfied me well as a good turnkey choice. But what's kept me from going the aftermarket route is the cost of rebuilding.
What's the real scoop here? Do they really require rebuilding every 10,000 miles (remember I drive 25,000 freeway miles per year)? Is rebuilding that expensive? Does it take a long time (how long would my car be down)?
I could afford a moderately priced aftermarket shock (new CR shocks I can get for $900), but not if I have to rebuild them a couple times a year.
Thanks, and sorry for the tangent here.
Are you having a specific issue with the CR shocks? CR shocks are the same high quality showa monotube as the AP1/2 shock, except they are valved for stiffer springs. As long as the spring rates are a good match to the valving, I think you will have a hard time improving on that setup significantly without spending lots more. But if you had to go aftermarket and are concerned about longevity you would want something that can be re built cost effectively. IMO, nothing will outlast the OEM shocks (CR or base), so with any aftermarket performance shock, you will have an increased service interval compared to OE. A quality aftermarket shock that can be rebuilt easily and affordably would be Bilstein.
