Sponsored by: Sake Bomb
Swift Springs on AP1
Old Jan 16, 2015 | 02:05 PM
abarca54's Avatar
Default Swift Springs on AP1
I have been searching on the forums and i havent been able to find out what i need. I want to lower my car just a bit to get rid of the big wheel gap. Seeing that the swift spec r spings are very popular on here i wanted to ask if it would be an upgrade at all to put on my ap1 with stock shocks. Or would I be better off being a set of proper coilovers?
2001 Spa Yellow
-AP2v2
-225/45/17 front
-255/40/17 rear
Old Jan 17, 2015 | 04:32 PM
PureFunction's Avatar
The spec r runs a higher spring rate in the front than the rear. This gives slightly more grip in the rear. In regards to feel, i say they are better than stock. in regards to cornering speed, i would say it is about the same as stock.
The drop looks good.
They are slightly bouncy on some roads.
Of course a proper coilover would be a better option if it is in the budget.
Old Jan 18, 2015 | 04:51 AM
deepbluejh's Avatar
Exactly right... adding a stiffer spring without also upgrading the damping rate is going to cause "bounce". People who only care about going "low" and can't afford or won't be bothered with proper coilovers can be seen bouncing down the highway at any given time.
My opinion is either do the mod right or leave the car stock.
Old Jan 19, 2015 | 06:39 AM
Slowcrash_101's Avatar
Spec r's are right on the edge of what a new shock can withstand. It'll wear an old shock that's lost some of its valving.
Old Jan 19, 2015 | 08:53 AM
abarca54's Avatar
Thanks for the input guys i will probably stick with stock for now and upgrade to a proper coilover system when the funds are right!
Old Jan 23, 2015 | 12:00 PM
2ks2knyc's Avatar
I had Swift R's on AP2 shocks on my AP1. The shocks had under 30k miles on it. The drop was nice. The ride IMHO was terrible. They handled great but ride was stiff and in time my front right started to bottom out. I daily drove the car up in NYC and found it torture on some roads and highways.. not to mention my lower back lol.
Depending on how you drive your car there are tons of options. If you are going to daily drive it all over nothing beats Eibach and OEM for the money. I have driven in a car with Spoon springs and those were very nice as well. It's not a horrible idea if you get new shocks with the springs.
my 2 cents
riceball777
Nov 4, 2011 06:07 AM
Neuman04
Sep 8, 2010 11:06 AM
mlc
Mar 27, 2009 09:07 AM
Truvietz916
Sep 21, 2008 09:13 PM
ExTex
Apr 27, 2007 06:10 PM
