Tein flex's
I've had them on my car for at least 6 months, I however have it set very low, for the look. It's setup on about medium stiffness. It handles decent when i have to make an abrupt turn or lane switch however when I make a fast long or wide turn, the car stars to oversteer. I realize that this is most likely from being so low so I'm willing to make changes to have the car handle better than stock ( if possible). I'm running 255s in rear, (CR setup) which i read is fine. My question is, how do I setup the suspension to where it should be and what else can I do to make the car really grip the road? I can put suspension on and off but when it comes to tuning it, I'm lost.
Thanks for any help
Thanks for any help
corner balancing will help A LOT!!!
as far as your height specs, you can go too low and itll handle poorly. when in doubt, take it to a shop that knows how to set it up properly if youre unsure to yourself.
