Sponsored by: Sake Bomb
Tein flex's
Old Jan 27, 2010 | 03:47 PM
HiRpmVTEC's Avatar
Default Tein flex's
I've had them on my car for at least 6 months, I however have it set very low, for the look. It's setup on about medium stiffness. It handles decent when i have to make an abrupt turn or lane switch however when I make a fast long or wide turn, the car stars to oversteer. I realize that this is most likely from being so low so I'm willing to make changes to have the car handle better than stock ( if possible). I'm running 255s in rear, (CR setup) which i read is fine. My question is, how do I setup the suspension to where it should be and what else can I do to make the car really grip the road? I can put suspension on and off but when it comes to tuning it, I'm lost.
Thanks for any help
Old Jan 27, 2010 | 05:43 PM
Jaydem's Avatar
take it to a shop, have it corner balanced....go from there
Old Jan 27, 2010 | 06:16 PM
justind's Avatar
corner balancing will help A LOT!!!
as far as your height specs, you can go too low and itll handle poorly. when in doubt, take it to a shop that knows how to set it up properly if youre unsure to yourself.
Old Jan 27, 2010 | 06:27 PM
SOHCmyDOHC's Avatar
go to teins website and check for "recommended" settings. They have the install PDF's there.
Once you figure out the height you wanted corner balance it like other have said
Old Jan 27, 2010 | 06:33 PM
iam7head's Avatar
it's one of those thing that if you have to ask, you'll better off taking it to the pro
most guys can adjust all the part but not much people know how to set it up right.
Old Jan 27, 2010 | 07:40 PM
HiRpmVTEC's Avatar
I just want to be as low as possible while having the handling better than stock. I'll take it to a shop as well
HiRpmVTEC's Avatar
Thanks for the input so far btw!
Old Jan 28, 2010 | 09:36 AM
HiRpmVTEC's Avatar
What would happen if I gave it more neg camber and kept it low? Besides tire wear being worse?
Old Jan 30, 2010 | 04:52 PM
HiRpmVTEC's Avatar
With the proper setup, can my car handle better than stock with JUST the tein coilovers ?
Old Jan 31, 2010 | 12:31 PM
HiRpmVTEC's Avatar
A little help?
