are these brake pads and/or rotors worn?
weird thing is.... im starting to hear screeching coming from the RR ... thats the one that is pictured.
however, the thickness looks (to me) very healthy. the FRONT however, FR, atleast, looks like it has no pad left....
For $40 per axle, it's not expensive to replace a set of older pads if you're already going through the trouble to take them off and check everything.
so you suspect the rear inbound pad are worn? it was too dark and too tight to stick my head in there last night
guess ill just get 4 sets all around from Handa
rears look fine to me.
fronts........ hard to see the inner facing side of the rotor but from the picture, it looks DANGEROUSLY thin. also, the way to measure the front rotor is from one side to the other including the gap for the cooling vanes.
you need to do front rotors and pads.
Originally Posted by Mondo131,Aug 23 2010, 01:18 AM
In need of replacement? Doesn't look like it. Call your dealer and ask what the minimum thickness is for Rotors.
