"thinest" BBK ?
Right now i am running a 17x9.5 +44 Work XD-9 and 255 starspecs on all 4 corners. I need to figure out which Brake kit has the thinnest caliper allowing for the most clearance? i got bit by the DE/HPDE bug and cant stand my stock brakes now. What do you guys think?
I think those actually clear the StopTechs even in a +63 offset. Just print out the template from the StopTech website and check.
i would def try pads and fluid first like stated above. but to answer your question i would say the Wilwood kits are the "thinnest"
https://www.s2ki.com/s2000/topic/970...ock-cr-wheels/
right now im using HP+ pads, all braided lines, and amsoil fluid. Im also making 400-600whp (depending on what tune i run) i need something more. ill be checking my clearances for the wilwood kit and if that doesnt work, ill just buy some wilwood calipers (according to my research they are the thinnest) and have some rotors made that sit further in. and obviously custom brackets. wish me luck lol
