Sponsored by: Sake Bomb
Upgrading S2000 break system
Old 07-08-2017, 08:11 AM
vassilis_t's Avatar
Default Upgrading S2000 break system
I would like to upgrade the break system for my Honda S2000 because under heavy driving in mountain roads it fades. What are the best upgrades? It is a 10/2004 European version.
Thanks in advance, Vassilis
Old 07-08-2017, 09:11 AM
Memo6453's Avatar
what fluid do you use? SS lines and a higher boiling point fluid might be all thats needed...
Old 07-08-2017, 09:38 AM
lookstoomuch's Avatar
Likely you just need some pads which have higher heat capacity.
Old 07-10-2017, 12:00 PM
Car Analogy's Avatar
Received 1,321 Likes on 999 Posts
Agree, start with known good, clean quality performance fluid and good pads. See if that resolves things.
Old 07-10-2017, 12:13 PM
starchland's Avatar
It's impossible to upgrade the break system
The following 4 users liked this post by starchland:
freq (07-18-2017), HatTrickHokie (07-18-2017), RedCelica (07-18-2017), rokkerkory (07-15-2017)
Old 07-13-2017, 08:28 AM
True! Our cars don't have a break system, and are very reliable.
They do of course have a brake system.
Its sad when you aren't even fluent in your birth tongue (not that we know that is the case here, but you see it enough that the statement is still valid).
Noble (07-28-2017)
Old 07-15-2017, 11:46 AM
rokkerkory's Avatar
I dont want to break anything lol
Old 07-15-2017, 02:28 PM
Bama Dave's Avatar
Look at the ATE dot 4 brake fluid and the Carbotech AX6 brake pads. Make sure to bed them correctly. Later
Old 07-18-2017, 03:51 AM
beefystud's Avatar
this is what you need
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: Brembo GT-R Big Brake Kit - Honda S2000 Rear 2000-2009 (328mm)
Old 07-19-2017, 10:41 AM
Inspired's Avatar
Strong Honda-Tech post.
Quick Reply: Upgrading S2000 break system
