Sponsored by: Sake Bomb
Upper Strut Bar Torque Sequence
Old Sep 17, 2012 | 03:04 PM
zeroptzero's Avatar
Default Upper Strut Bar Torque Sequence
Hi I bought a used front upper strut bar, it is an ASM 4 point bar that ties into the lower subframe at the eps bolts. I didn't get any instructions with it, but I was wondering if you do the final tightening torque with the front wheels lifted off the ground, or with the front wheels on the ground ?. Or maybe it doesn't matter ?.
Thanks for any replies.
Old Sep 18, 2012 | 01:43 PM
zeroptzero's Avatar
I couldn't wait around for a reply so I ended up installing it with the wheels off the ground, it seemed to slide on easier that way, not sure if it makes much of a difference either way.
Old Sep 19, 2012 | 04:21 PM
IntegraR0064's Avatar
It won't make a difference for a strut bar. For anything that'll actually get preloaded like a sway bar or something with bushings you'd want to do it on the ground, but for a strut bar either way is fine.
Old Sep 19, 2012 | 05:50 PM
zeroptzero's Avatar
Thanks for confirming that, makes me feel better knowing it is all the same. I thought the bar fit onto the towers better when the front end was lifted, it was a really tight fit prior to that for some reason.
Old Sep 20, 2012 | 01:32 AM
SOL1D's Avatar
Usually if its a one piece bar it fits going on the strut tower points easier lifted because the chassis snags on both sides, even if it snags just a FEW centimeters it helps alot with one one piece bars. I've noticed that with every car I've owned that I had a 1 piece bar fitted, I'd have to jack it so there was no load on the strut tower points. Guessing even if its been a couple of years, those strut bars were tested and fitted on a pretty new car that was un-moddified car.
Old Sep 21, 2012 | 05:42 PM
zeroptzero's Avatar
Originally Posted by SOL1D
Originally Posted by JFUSION' timestamp='1348105839' post='22024623
[quote name='IntegraR0064' timestamp='1348100473' post='22024467']
[/quote]
yeah that is what I found too, it is a one-piece bar and it fit easier with the front end lifted.
mongomery1234
Jul 30, 2014 08:13 AM
it'S2klean
Apr 12, 2011 07:59 AM
it'S2klean
Apr 8, 2011 09:01 PM
Z3toS2K
Dec 6, 2000 10:30 AM
