06 ap2 drl problem
Old Dec 7, 2012 | 08:45 AM
atlasshrugged's Avatar
Default 06 ap2 drl problem
Bought some super yellow 3300 k drl h1 bulbs from pwjdm and installed them today. For what ever reason the will no longer turn on. However, the brights work just fine and the fuse is not blown. Has any one had experience with this. If so feedback and suggestions would be great. Thanks for the help.
Old Dec 7, 2012 | 09:41 AM
SlowTeg's Avatar
So all you did was swap the high beam bulbs and install HIDs? So the DRL's don't work, but when you flick on the high beams the HIDs come on? If that's the case sounds like your HIDs aren't getting enough voltage, and hence not turning on. Someone else can correct me if I'm wrong but the DRL's work by underdriving the high beams by feeding them a lower voltage (other than 12V). That might not be sufficient for the HIDs.
Old Dec 8, 2012 | 09:28 AM
I was thinking the same thing but my stock bulbs no longer work either
JS2k.com
Dec 21, 2020 07:43 AM
Chuck S
Jul 27, 2014 05:41 AM
Silentlight
Jan 12, 2014 08:21 PM
rrounds
Oct 20, 2011 03:41 PM
top.secret
Aug 17, 2011 07:27 AM
