06+ seat removal
Old Mar 20, 2008 | 06:33 PM
laguna2s2k's Avatar
Default 06+ seat removal
I wanted to remove the seats for install of a new system. But crutchfield and owners manuel, warn of malfunction of the srs sytem if you remove the seats! Has anyone had any problems like this???? I can Install without removal but it would rather take then out! anyone?
Old Mar 21, 2008 | 04:16 AM
NFRS2K83's Avatar
u shouldn't have any problems when removing the seats... just disconnect the negative battery cable before you do so... this will prevent any unecessary lights from popping up on your dash board...
Old Mar 21, 2008 | 05:30 AM
Carson07S2K's Avatar
Should be 4 bolts and a few wire harnesses
Look at you putting in a system without telling me! What are you installing?
Old Mar 21, 2008 | 06:28 AM
Wiggum's Avatar
Thieves in Central Florida aren't have a problem with this at all..
Old Mar 21, 2008 | 06:59 PM
R1_Pilot's Avatar
Thieves dont have problems ... but the owner's do. Do not ask me how I know.
I had an SRS light due to the passenger side seat's weight sensors. You might need to have them recalibrated so think this through before giving it a shot.
I now have Brides and I removed the passenger once and the SRS popped up.
This happens on the '06+ . You can remove the driver's side seat as many times as you want without problems.
Joaquin
Old Mar 22, 2008 | 07:34 PM
laguna2s2k's Avatar
Thanks! I left them and worked around them, a bit more stretching around but it worked out really well.
Old Mar 23, 2008 | 11:04 PM
R3DS2K's Avatar
Joaquin
still under warranty.. you can get it recalibrated under warranty hehe
Old Mar 23, 2008 | 11:43 PM
Jrz's Avatar
Jrz
I removed the seats when installing my system with no problems. I did undo the negative cable before I started as you should before installing anything like this. Gl.
Old Mar 26, 2008 | 04:28 PM
TJR's Avatar
TJR
I removed both seat to install seat covers and no problem, and I forgot to disconnect the battery.
Old Apr 6, 2008 | 09:08 PM
laguna2s2k's Avatar
Im a Puss, did the install around the seats, it worked out but thanks!
