10w3 vs. 10w6
Old Jan 26, 2006 | 11:13 PM
DJFriar's Avatar
Default 10w3 vs. 10w6
What's the difference between the JL Audio 10w3 and the 10w6? I see that the w6 is rated for 100W more power, yet needs slight less cu ft of air space. It also has a slightly larger mounting depth, and a little more weight. But sonically what's the difference between them? Does one sound better than the other, or is better for a certain type of music than the other or ???
Old Jan 27, 2006 | 12:02 AM
SeattleJason's Avatar
From my personal experience with the setups I've seen, 10W6v2s have tighter, punchier bass.
I'm actually disappointed that all JL Stealboxes have W3s, when W6s would fit in most of the boxes just fine.
Old Jan 27, 2006 | 05:35 AM
DJFriar's Avatar
That's actually what I was thinking when I asked this question, is that it look like the W6 would fit, as long as the extra 1.25" or so would fit. The air volume needs of the W3 is .75, whereas the W6 is .625, so I would think it would work fine.
Old Jan 27, 2006 | 06:03 AM
jwa4378's Avatar
The 10w6 has larger magnets, and a different shaped cone (i think). It hits harder, but some say it sounds "boomy". The excursions should also be difference, with the W6 xmax being greater than the w3.
As far as volume is concerned, if you are using a tool-well enclosure, it will not be a problem for either. You can get up to 1.25-1.5CF (depending on materials used). It you want a WLAURENT style enclosure, you will need a sub with ~.50 CF requirement, and a rather shallow mounting depth.
For that money, get a Boston Accoustic G510. Requires ~.50 CF, excursion is greater, bass is tighter, sub is more musical sounding (less "boomy"), the parts are interchangeable (incase you fry a Voice Coil), and the power handling is 450wrms.
Just my $.02 (I am biased, though, as I own a G5 )
John
Old Jan 27, 2006 | 07:17 AM
lyndon_h's Avatar
John
I love your disclaimer. It reminds me of when TV financial advisors give stock recommendations and have to disclaim that they own shares of the stock.
I personally have the 10w2 and think it sounds good in my custom tool well enclosure, but i think JL subs are a tad overrated. My next sub will definitely be a boston Acc or an Infinity as i think they have a purer sound.
-LAW-
South Florida
Jul 5, 2010 06:47 PM
Scot
Aug 4, 2008 09:21 PM
sleeze
Jan 1, 2006 09:09 PM
Louie
Jun 26, 2003 10:12 PM
Tifosi Red
Jul 26, 2002 01:00 AM
