12 volt source with ignition on...
Old Aug 14, 2013 | 06:54 AM
cmn's Avatar
cmn
Default 12 volt source with ignition on...
Does anyone know where to find a connection as described? Even the accessorie point in the "under dash fusebox" gets cut when pressing the startbutton. I need the source for my boost gauge, as it resets the gauge when cutting the power, and therefor showing wrong values.
Anyone?
Old Aug 14, 2013 | 07:39 AM
d-bo's Avatar
Wouldnt it correct itself as soon as it reads vacuum ? what gauge is it ?
You could use the ignition harness if you really wanted
Old Aug 14, 2013 | 07:53 AM
cmn's Avatar
cmn
It's AEM analog boost gauge. It resets itself when the power is cut, and all points I have found so far cuts the power when you push the start button. So when I start the car it says the pressure is 0 bar, and not ^-0,5(?) which is correct at idle. I need somewhere that gives continous power from the ignition is turned on till it's turned off again.
But maybe I'll try the switch itself.
Old Sep 2, 2013 | 06:30 PM
Ken_SNISEN's Avatar
you can try using a small 12v capacitor (or wire together a few lower voltage capacitors to make a 12v output) on the power line for the gauge. i used this setup to keep my stereo from restarting when starting the car. adding a diode to this might be a good idea as well.
there should be enough power from the ignition power line to handle the gauge. but i don't like how the voltages jump around so i choose to use capacitors.
Old Sep 2, 2013 | 10:55 PM
cmn's Avatar
cmn
Would one of these work for example? http://www.ebay.com/itm/2-Pcs-Capaci...item2c6cbac5ff
Old Oct 10, 2013 | 11:03 AM
cmn's Avatar
cmn
Hmmm. I have tried several places to connect the gauge for 12 volt power (even when the starter is running), but can't seem to find a working place. Even the "accessori plug" under the dash cuts power when pressing the startbutton. Any other suggestions? Any links to an example of capacitors I can use maybe?
Old Oct 10, 2013 | 07:21 PM
99SH's Avatar
There is a constant 12V source. I had the same issue with my boost gauge but found a constant/switched 12V tap location. I'll check my notes...
Edit: Try Fuse #3,5,6,7,8 in the underdash fuse box. Any of those will work.
Old Oct 11, 2013 | 06:41 AM
cmn's Avatar
cmn
Thanks! I'll try it out.
Old Feb 17, 2014 | 10:52 PM
cmn's Avatar
cmn
Just thought I'd update for future reference. I ended up getting power from fuse #7. That fuse goes to the hazard light switch. As the gauge is mounted in the dash where the cd-player originally is placed, and the fuse goes for the red/blue wire to the hazard switch, it was very easy to get power from that wire to the gauge. And it works perfectly. This was a lot easier than connecting at the under dash fuse box.
mikefifth
Jan 17, 2015 02:12 PM
s2kseven
Jan 18, 2013 06:50 AM
Nyther
Jul 8, 2011 12:13 AM
Competitor9
May 8, 2010 03:05 PM
