12V source while cranking
Old Jul 7, 2011 | 12:10 PM
Nyther's Avatar
Default 12V source while cranking
My autometer 3376 Boost gauge needs a 12V accessory source that HOLDS its power while cranking...
I used the iginition source in the under dash fuse panel but that won't hold 12V while cranking so my boost gauge reads inaccuratly..
i COULD make a switched 12V straight source from the battery or fuel pump but that's a bit too ghetto for me..
I was wondering is anyone knows where to find a 12V source thats switched on by accessory ( moving the key to ign. ) and holds the power while cranking...
Thanks!
Old Jul 7, 2011 | 12:15 PM
boostedf22c's Avatar
White w/ red stripe (10-12 gauge wire) on your ignition harness is 12v constant, even when cranking. But is also switched to off when the key is off.
There are several ways to tap into that, but that's the wire you'd want to use.
Old Jul 7, 2011 | 12:17 PM
Nyther's Avatar
Great! I'll try to peel something off the outer layer and solder a wire to that one!
Old Jul 8, 2011 | 12:13 AM
Nyther's Avatar
Solved!
Thanks!
mikefifth
Jan 22, 2015 01:32 PM
cmn
Feb 17, 2014 10:52 PM
flexer
Feb 1, 2009 07:10 AM
Forcedbird
Dec 4, 2008 07:30 PM
TwiztedS2K
Feb 6, 2005 10:40 AM
