2004 conversion problem...
Believe it or not I've been working off and on repairing my s2k back to its original state. I blew the engine back in 06 and slowly but surely have put forth the effort in getting everything put together...
I started the car today and it runs amazing!!!!!!! problem is, back when I bought hardtopguy.com's light conversion kit, well, let's just say I began the project and never finished. I have the lights fitted and installed. Now the big question remains...
Somehow, I lost the 3 plug brake light connector and have the wires laying out individually...
My blinkers are set up perfectly, as well as my back up lights.
I have 5 wires remaining, all of which belonged to the AP1 brake lights... however only 3 pins are needed to power the new brake lights and running lights I would assume?
With the current set up I've been able to get the brake lights to illuminate upon brake pedal movement... the center of the "o" ring lights up but the outer one does not... and I have 2 wires (still connected to the white connector from the ap1 version) that ran the running lights...
I have brake lights... the middle ring at least, but no running lights...
Which of the 5 wires should I plug into the 3 pins from the brake light? which order? what to do with the remaining 2?
Any help on this issue would be awesome!!! I've searched everywhere!!!!
ps. I've already purchased the wire harness from hardtopguy to fix the problem permanently... but need a quick fix for July 4th.
HELP!!
HELP!!!!!!!!!!
HELP!!
HELP!!!!!!!!!!
Duo
Jul 19, 2010 08:14 AM
