2004 Taillight Conversion Wiring
Old Mar 7, 2008 | 05:06 AM
  #131
sbabys2000's Avatar
Does anyone know the part number for 04-06 turn signal light socket ? because the AP1 turn signal socket was too big for the AP2 tail light...
another question is if i got these AP2 turn signal sockets..Will they fit the AP1 plug connector ?
Old Mar 7, 2008 | 07:51 AM
  #132
S2005x's Avatar
I think thats the part they have been grinding down.
Old Mar 7, 2008 | 03:24 PM
  #133
sbabys2000's Avatar
So.....Whats the solution for the AP2 turn signal light ?
The final socket is perfect fit the reverse light and AP1 connector also fit the brake/park light after some cutting ...but i have no idea about the turn signal light
Old Mar 7, 2008 | 03:26 PM
  #134
S2005x's Avatar
I'm not sure... to be honest...
We just used the AP2 Wiring harnesses...
Sorry I cant help. PM the Original Poster
Old Mar 7, 2008 | 04:49 PM
  #135
sbabys2000's Avatar
The NEW things i found is the AP1's reverse light socket and brake/park light socket are BOTH can be fit onto the AP2 turn signal light hole !
but if use the AP1's brake/park light socket .The problem was socket has 3 pins but the AP1's original plug of turn signal light only has 2 pins
AP1's reverse light socket and turn signal light plug are both has 2 pins but need some mod on the plug to make it fit , This is the way i gonna try...Sad thing was i cant try it because if i make a wrong choose then i cant go back to the begining
Old Mar 8, 2008 | 07:45 AM
  #136
S2005x's Avatar
ah, im confused
Old Mar 9, 2008 | 11:50 PM
  #137
lolo79's Avatar
There is a light bulb mod you need to do in order for the light to still work even though it's only plugged into 2 of the pins. Yes there are 3 pins and only 2 holes, that's OK, just do the bulb mod on the begining of this thread where you need to fold the pin across to the other side of the blubl. Then just plug it in. It should work fine, if it blinks too fast that means you plugged it into the wrong two pins (for example, there is a left pin, center pin, and right pin...you can either plug it over the left and center or the right and center), just switch it to the other side. Damn, sounds confusing but it's not. Hope it works out for you.
Old Mar 11, 2008 | 01:10 AM
  #138
sbabys2000's Avatar
Hey guys~Thank you for your info!
I have done my left side AP2 Tail light conversion...I still found some problem ~
I did mod the plug for the brake light but the brake light sometimes does not work.maybe is due to connection problem !
As we all know the AP1 reverse light socket will fit perfect onto AP2 tail light . and i used another reverse light socket to fit my AP2 turn signal light .Its works but the RED circle around the turn signal light does NOT response !
There was a little gap between the new tail light and the car body
BTW :the cutting job makes my sick!
Old Mar 11, 2008 | 01:17 AM
  #139
sbabys2000's Avatar
Old Mar 11, 2008 | 02:11 AM
  #140
Reds2kracer's Avatar
The ring around the turn signal is not suppose to be lid, it's a reflector ring I believe . The only rings that's suppose to light up would be the LED one on the stop lamp when you turn the lights on.
