Are the 2005/2006 door panels the same?
Old Sep 12, 2006 | 07:03 PM
Silvers808's Avatar
Default Are the 2005/2006 door panels the same?
I'm thinking about buying the Tweeter grills and parts to modify my 2000 Door panels.
If anyone has pics front and back it would be great.
Trying to make sure i order the right parts
24621 032 AR SCREW, TAPPING (4X10) (PO) NO COLOR 1.51 1.14 Qty: 4
1470472 034 1 GRILLE, R. TWEETER GRAPHITE BLACK 23.23 17.42 Qty: 1
1472521 035 1 GRILLE, L. TWEETER GRAPHITE BLACK 23.23 17.42 Qty: 1
1470936 038 4 COLLAR NO COLOR 1.43 1.07 Qty: 4
2005 Door Panel Parts
does it look like I'm missing anything? I'm planning on using aftermarket tweeters, just want the grills to look OEM. Anyone else tried this?
Old Sep 12, 2006 | 08:09 PM
AlanL's Avatar
What they don't show you in these pictures is the specifics of the mounting posts on the rear side of the grills. The mounting posts don't leave a lot of room for aftermarket tweeters. I had to cut these off in order to get the tweeters for a set of Diamond 661s to fit behind them. I made up a set of mounting boards out of 1/4 pressed wood and used the remaining stub of the mount posts to fasten them in place. The end result does appear stock as you see it from inside the car.
The good news is that a new set isn't all that expensive and I did buy a new set to replace the ones I modified in case I ever decide to try to make the sound system stock again.
Old Sep 13, 2006 | 12:09 AM
Silvers808's Avatar
do i need 2 collars and 2 screws to hold in each grill?
Old Sep 13, 2006 | 03:54 AM
AlanL's Avatar
yes.
Old Sep 13, 2006 | 08:05 AM
oth's Avatar
oth
the '00 & '05 door panels are not the same, so you should confirm with
someone who has done it that the '05 grills will fit properly. on your
diagram, parts #24 and #28 are the tweeter pods originally added to
the AP1 doors in '02 or '03 which will certainly fit. again, I don't know that
the '05 ones won't fit, only that you need to be cautious as some aspects
of the door panels did change.
Old Sep 13, 2006 | 11:11 AM
Silvers808's Avatar
I understand, at this point im unsure if anyone has done this retrofit. I'm still trying to decide if I want to do this.
can someone take a pic of the driverside panel for me? id like to see the shape at the top.
From what i remember from seeing online they look the same over all shape L/R as the '00 door panels, which is the most major concern.
Old Sep 20, 2006 | 07:50 AM
Persuader's Avatar
I was thinking of something similar but I was going to do a complete swap of the door panel. (BTW, does anyone know if the MY05 door panels can be installed into a MY01?) However if there is not a significant difference in the shape of the door panels between years then this would probably save me some money.
If any one has tried this or something similar I would love to hear any tips. I am sure Silvers808 would also.
Old Sep 25, 2006 | 02:29 AM
brunodkid99's Avatar
This is what I did with an '06 door tweeter. I had a problem with fitting a 2 inch aftermarket tweeter to the OEM grill. So I made a custom bracket and used the 2 collars and 2 screws to hold the bracket. I had to cut the OEM tweeter mounting screws.
altahina
Mid-A Swap Meet
Jul 10, 2015 07:00 AM
K_iju
Apr 14, 2015 11:41 PM
Pro-PC
Apr 19, 2011 06:09 AM
jdm knowledge
13
Mar 2, 2006 05:32 PM
ayelien
Feb 5, 2004 12:47 PM
