200W System Kills Battery
Old Nov 13, 2012 | 10:50 AM
JohnsS2000's Avatar
more than likely the light assembly needs removed and cleaned up. Mine had issues for awhile and when I took it out and took it apart & cleaned it I have not had any more problems.
Old Nov 14, 2012 | 11:19 AM
s2krazy01's Avatar
Originally Posted by Ragnarok043
if you really think that the sound system is causing it i would disconnect the system to see if it has any effect. you can also try to diagnose the problem with a multimeter(if the drain isnt strong enough to light a test light) to measure amperage draw between the battery negative and ground like with test light. if you do see an amperage draw then 1 by 1 pull fuses from the fuse box til you the amperage draw disappear then youve pin pointed battery drain is coming from.
Good idea. I'll try the multimeter while also making sure the light switch is in the OFF position.
I'll do that.
Old Nov 14, 2012 | 01:06 PM
oth's Avatar
oth
A couple things:
1) your ground(s) should be way less than 1 ohm.
2) your battery drain could happen if the amp(s) are not shutting off when
the remote wire from the headunit turns off. You could check this by removing the
fuse to the amps when all is off, and then putting your multimeter on them set to
"DC amps" and seeing if there is current flowing.
akesh45
Nov 10, 2023 09:08 AM
Ks320
Apr 25, 2009 04:49 AM
hornyhonda
Sep 3, 2006 11:59 AM
CostaK
May 8, 2004 05:45 PM
seung
Oct 2, 2002 06:21 PM
