4 speakers and a sub...
Old Apr 28, 2007 | 09:22 PM
meriggi's Avatar
Default 4 speakers and a sub...
If I install 4 speakers and and a sub, can I use my exsisting [Kenwood] 4 channel amp? Have you done this?
I know, it would be better to go with a mono for the sub, but I really don't want to get two amps. Or, should I spring for a 5 or 6 channel amp???
Thanks,
-Steve
Old Apr 28, 2007 | 09:34 PM
DDuds2k's Avatar
depends on the wattage man. Ive heard of running 2 speakers and a sub off a 300/2...it just isnt going to be the best quality. You would have to run 2 sets of speakers through 2 channels...might not get a very good result. I hope someone can answer this question better for you than I. But...if its a 4 channel amp, its prob not going to be a whole lot of wattage running to your sub either.
Best thing to do would be get a small amp just for your sub. You can probably find one on ebay for like 50 bucks.
Old Apr 29, 2007 | 04:25 AM
darkknight1999's Avatar
Run your door speakers off the front channels of the amp, run the rear speakers off the headunit itself and run the sub off the rear channels of the amp(switch the rear channel to low pass on the filter settings)
Old Apr 29, 2007 | 05:41 AM
Cubs2k's Avatar
I have mine set of this way....works great.
Old Apr 29, 2007 | 08:07 AM
DDuds2k's Avatar
didnt even think of running the rear speakers off the HU. Im dumb
Old Apr 30, 2007 | 11:02 AM
STC1709's Avatar
or you can run the drivers side speakers on channel 1 and run the passenger speakers on channel 2 (front channel) then bridge channel 3 and 4 so that your sub will be bridged on channel 3 and 4 (rear channel) thus turning your 4 channel amp into a 3 channel amp, ive been doing this for a long time now, and shit sounds loud and awesome
Old Apr 30, 2007 | 05:01 PM
Cubs2k's Avatar
The down side to that is you lose the ability set the fader...
Old Apr 30, 2007 | 06:34 PM
STC1709's Avatar
but who ever uses the fader? not me, i dont know anyone who does, and i dont see the point in needing to use it
Old Apr 30, 2007 | 09:14 PM
RCHB's Avatar
if you decide to geta new amp:
memphisbelle
S2Kmonkee
Jan 25, 2010 03:17 PM
scott2055
Apr 26, 2007 03:28 AM
devilchrist
Jun 29, 2004 03:45 PM
j_c_a
Jun 4, 2003 08:44 AM
SpEeDxXxRaCeR
Jan 22, 2003 12:56 PM
