5 Channel Amp
Old Apr 6, 2002 | 06:30 AM
PAS2KNut's Avatar
I'm looking for a five channel amp. I currently have an Xtant 404M that I like very much but need the extra channel for a sub. I don't want to add another amp because of storage reasons, and would like to just replace the Xtant with a new 5 channel amp. The Xtant is in the trunk above the jack in a custom built space. Any recommendations out there. Thanks for your assistance.
Old Apr 6, 2002 | 08:00 AM
WLAURENT's Avatar
I tried an Alpine 5channel that worked great - I believe it is 4x60 + 1x120
However I brought it back and put two Rockford amps in the car - 1 in trunk (mono block) and 1 under drivers seat (4 channel without end caps) - planning to add Lucids rear kit soon.
Old Apr 6, 2002 | 08:16 AM
PAS2KNut's Avatar
Interesting that you replied to my post, because it's your sub enclosure that has me asking this question. I will check out the alpine products.
Thanks
Old Apr 6, 2002 | 08:42 AM
lucid's Avatar
I'd say do it right, get 2 of his enclosures and a Class D amp.
Old Apr 6, 2002 | 12:17 PM
Speedracer's Avatar
Pass2knut...get the Xtant X604. I have the X603, it's a three channel. Is this amp for your car?
Old Apr 6, 2002 | 04:20 PM
PAS2KNut's Avatar
[QUOTE]Originally posted by Speedracer
[B]Pass2knut...get the Xtant X604.
Old Apr 7, 2002 | 05:04 PM
gohiking's Avatar
I suggest the Cadence Z6000. Good stuff, reasonably priced. Check it out at CadenceSound.com. It's just being launched...should be available very soon.
Z6000
6 Channel Stereo Amplifier
Power:
4 X 150 + 1 X 400
Chacteristics:
Input Voltage: 150mV-8V
THD: <0.044%
Response: 10Hz - 40Khz
S/N: >100dB
Damping factor: >200 @ 100 Hz
Old Apr 12, 2002 | 09:18 AM
Speedracer's Avatar
Pass2knut....my bad, the 604 is a four channel
Old Apr 12, 2002 | 11:47 AM
gohiking's Avatar
FWIW -- the Cadence Z6000 is now available, and you can run it five channel (that's what I'm doing). It's also DTS certified -- has a distinct center channel and sub channel. Very impressive piece...
Old Apr 12, 2002 | 07:36 PM
PAS2KNut's Avatar
[QUOTE]Originally posted by gohiking
[B]FWIW -- the Cadence Z6000 is now available, and you can run it five channel (that's what I'm doing).
