99-00 Civic EK fog light install question
Old Feb 27, 2007 | 05:13 PM
AP12001's Avatar
Default 99-00 Civic EK fog light install question
hi, speaking of the EK foglights being installed in the s2k, i had a question...
we are trying to install the wiring of the fog lights, but we are confused.. there are two female spade connectors (white and red) and two male spade connectors (blue and blue/orange stripes) that we do not know where to plug into.. could you pls help me out if you can.. we are trying to install these lights tonight and are confused as to where those connectors should go in the car?
thanks!!!
Old Feb 27, 2007 | 08:46 PM
nMeOnE's Avatar
i had alot of trouble with my EK install too , buts its fairly simple...
Even though no one helped me when i posted i'll help you as best as i can explain. The best way to do it is to not even use the switch at all.
Basically run a 20 gauge wire into your cabin behind the battery (little grommet) then behind the radio and into the fuse box on the driver side. Then you will see 3 male plugs that contains the constant power, driving lights, and remote i believe. Go to autozone and get a female connector and connect it into the driving lights so it would provide you with a fused connection into your relay.
Your relay contains 4 wires. A red/black, orange/blue, white and black.
White goes to battery. Black is ground, Orange/blue goes to the wire you just ran into the cabin and red/black goes to the EK fogs.
Or i could be mistaken and its red/black goes into wire into the cabin and orange/blue to the EK foglights. Just test it out but its one of them.
Henwhee
Feb 27, 2012 08:34 PM
KnowledgeIsPower
Sep 23, 2007 11:42 PM
KnowledgeIsPower
Sep 18, 2007 06:02 AM
