AEM EMS coolant gauge working (to a degree)
Old Sep 22, 2005 | 07:34 AM
gilbertg's Avatar
Originally Posted by honda9krpm,Sep 22 2005, 07:45 AM
Giles, is Injector 9 the same as Fuel 9?
It certainly is You can use the EMS's gear dependent shift light functionality and use this as the output. Just make sure you set the 0 column in the table to a really high number (25500) otherwise the light will get annoying when the car is moving slowly or between shifts. If you have rear gears you'll also need to modify the gear calibration.
Old Sep 22, 2005 | 04:06 PM
honda9krpm's Avatar
I have different rear gears and also different gear ratia in the box.
I have not had time to recalculate the gear calibration yet
So little time to get things done
Old Feb 27, 2006 | 11:48 AM
Vladimir Sochi's Avatar
Hi!
I have Civic 98 yeas-EK4-B16A6-SiR-P2T(ecu) and gauge cluster S2000)))All work Ok! but i wont converter for coolant temperature scale)) Ho help?
mnr vortx f20c
Sep 10, 2010 07:08 AM
CourageOO7
Aug 3, 2009 05:41 PM
Rajdlos
Jun 28, 2008 08:07 PM
Toad17
May 23, 2008 05:49 PM
s2k2go
Aug 9, 2004 10:05 PM
