alpine headunits compatible with the S...
Old Feb 4, 2005 | 03:35 PM
TriaXenginE's Avatar
Yes. Thanks, John. So if i just have 2 speakers in the S2000, i'd adjust the driver side for a little delay?
Old Feb 4, 2005 | 03:50 PM
darkknight1999's Avatar
Yup you got it! It will balance out the sound so it will seem like your sitting with the speakers exactly the same distance away.
Old Feb 4, 2005 | 03:52 PM
cool.
Old Feb 4, 2005 | 04:29 PM
If you go to www.alpine-usa.com You can go to the i-personalize section and sign up and set it up that way. Plus a you'll learn a little from doing it yourself.
You'll need to take a measurement from your front right speaker to your ear/head... should be around like 34" I think... I haven't measured it in a while.. so it could be a little higher.
BTW if you have seperates take the measurement inbetween them around the window switch.
Old Feb 4, 2005 | 04:34 PM
i see i see. yeah, i set up that i-personalize account a while back. didn't get around to putting it to good use.
Old Feb 17, 2005 | 07:00 PM
StookerToo's Avatar
Hey, would this time correction capability help fix the staging (and possibly brightness) issue when using S-Pods?
Old Feb 17, 2005 | 10:29 PM
Yes and no. It will fix the staging but the S-pod's will always be a bit bright. You can mess with the gains and try to get them not to be so bright but you'll have a rough go of it.
Old Feb 18, 2005 | 08:00 AM
CarmenOhio's Avatar
Originally Posted by darkknight1999' date='Feb 4 2005, 06:53 PM
With proper time correction the speakers will all sound the same distance apart... so that way the sounds get to your ears at the same time. Balance... other wise the speaker closet to your head will sound loudest...
So this works for only one person in the car, correct? A passenger might notice one side being a little louder even with the time correction?
Thanks,
Dave
Old Feb 18, 2005 | 08:26 AM
StookerToo's Avatar
I was planning on using the deck power from an Alpine 9833 to run the pods and then amp the doors and sub in the trunk. Am I correct that using the deck power I will not be able to adjust the gain, etc.?
i69myAp1
Sep 21, 2012 08:36 PM
CyrusA
Mar 22, 2004 08:26 AM
