Alpine Type R Component problems
Old Aug 12, 2006 | 07:11 PM
General Kratos's Avatar
Default Alpine Type R Component problems
So by going with what the above guys in the thread below said, I bought a set of alpine components for my S2000. Everything installed fine except on thing. The "plastic stop" that does not allow the glass window to go too high hits my magnet on the way down and it does not roll down all the way. Its too deep by about 1". The window has about 2-3 inch lefted before it dissapears into the door panels. YES, I put the spacer that came with the speakers on there too. I thought about taking the plastic knob off but it looks like it goes through the window to the other side, so that thought went out the window. UNLESS, its screwed in only, I undo the speakers to see cause I was in a hurry to go somewhere. I know a lot of you guys run these speakers, is it just me or its something you guys sacraficed as well for a good set of comps?
Thread where a few guys said it would fit fine and didnt mention any problems.
https://www.s2ki.com/forums/index.php?showt...l=alpine+type+r
Old Aug 13, 2006 | 01:25 PM
NFRs2000NYC's Avatar
You made a 1/2" spacer and they are still hitting?
Old Aug 13, 2006 | 05:07 PM
I didnt make one. I used what was given with the components, which seems more like 1/4" instead. Still with that, its still hitting about 1/2" of the magnet.
Old Aug 13, 2006 | 09:25 PM
If I remember correctly, the Type Rs need 3/4 inch spacer.
Old Aug 14, 2006 | 08:47 AM
smurf2k's Avatar
make some spacers yourself out of MDF
Old Aug 14, 2006 | 10:07 AM
Ok, the thread didnt state that so I assumed I didnt need it. Then I didnt know if the spacer I was gonna make would clear the door panels. But thanks for the info guys.
Old Aug 17, 2006 | 10:11 PM
suckmydohc's Avatar
A one inch spacer will clear the door panel.
Old Aug 17, 2006 | 11:43 PM
NICE, thanks for the info. That should help.
Old Aug 18, 2006 | 08:01 PM
MitsukillinS2K's Avatar
i used some washers to move mine out past the window. they worked fine that way
Old Aug 21, 2006 | 11:48 AM
SuzukaS's Avatar
crazy, i just got my Type X's in last night and i know they are deeper, had no issue with 1/2" foam spacer.
