Alpine Type R Component problems
Old Aug 22, 2006 | 07:10 PM
yumyumdimsum's Avatar
Go purchase 2 more spacers and they will fit in your door. I had to use 2 for each door cause the Type R components I have bang up against the glass. You might be able to get them free at Best Buy or any car audio retailer. I got mine for free! Well I also work for them too. My system was dirt cheap...hehehe
Old Aug 22, 2006 | 09:36 PM
General Kratos's Avatar
Already got it fixed. Did what the previous guys said, just made spacers out of MDF wood. Thanks for all the help guys.
Old Aug 23, 2006 | 07:33 AM
darkknight1999's Avatar
Make sure to paint the MDF. If water gets on it it will ruin them in 5 minutes... and then you'll add 10 pounds of water to the inside of the door. Paint um up!
Old Aug 23, 2006 | 08:28 AM
Yep, painted it gloss black.
Old Aug 23, 2006 | 10:04 AM
BlackBulletS2K's Avatar
I hate these speakers. They're too damn big for our car. Everytime I turn the bass up they rattle against the door panel. Do any of you guys have the same problem?
Old Aug 23, 2006 | 10:52 AM
They shouldnt rattle if they are not touching anything and tighten down good. I'm gonna guess you have something loose. That your your REALLY bumping them, then its normal.
Old Aug 23, 2006 | 11:23 AM
Im not really bumping them, my bass is at +1 on my stock HU. It sounds like they're bumping against the door panel. Is there anything else they could be touching or what else could be causing the noise? I'm pretty sure everything is tight.
Old Aug 23, 2006 | 03:27 PM
Can you take a picture for us?
Old Aug 27, 2006 | 07:15 AM
Mr.Motion's Avatar
haha I actually just installed these speakers yesterday in my S...I actually work for best buy mobile install. The Type Rs need a 1" spacer which you can get at best buy...mine were only 2 bucks with my discount lol but normally i think they are around 12 bucks. There still are problems using it though. Number one you need to mount the speaker as low as possible around the speaker hole to avoid hitting the bend in the door panel. #2 on the actual door panel itself...there is a plastic ring that goes around the fatory speaker with foam padding around it...this ring needs to be cut or grinded off the door panel. I did mine in about five minutes grinding away with a dremel. Other then that you shouldn't really have any problems with anything.
Also...Type R components do not sound good unless they are amped. Alpine makes a tiny 2 channel amp which works perfect in our cars. it's the 220 model. The Type r components can handle 70 watts rms and the amp puts out 50 rms per channel. I mounted this amp behind the passenger seat...ran the speaker wire and rcas through the center console under the padding...then brought the power wire in on the driver side...ran it behing the dash to the passenger side...down the door rail...and to the amp.
Only other thing I would really reccommend is to dynamat the doors...It helped alot in mine.
Hope this helps
Old Aug 27, 2006 | 07:17 AM
Mr.Motion's Avatar
Also mine do bump against the door panel somewhat...i'm gonna try to add some foam padding to try and cut it down...i'll let you guys know how i fix this.
dookiewhat
Jun 12, 2019 01:57 AM
Haulin' S
Jan 31, 2009 07:19 PM
s2ook
Nov 26, 2007 03:57 AM
BlkMagic
Oct 23, 2003 03:09 PM
Kibro
Jul 24, 2001 12:09 PM
