Alternate Amp Locations
Old Jan 13, 2005 | 06:59 AM
xxxCadillacxxx's Avatar
Default Alternate Amp Locations
Other than the spare tire space and the trunk well, is anyone on here putting their amp(s) in any other locations?
I am amp shopping right now and would like to do an install that retains the spare and leaves the trunk well stock.
I am looking at the space to the left of the spare tire as a potential, and under the drivers seat. Anyone?
Also, what do you guys think of the MB Quart RAA4200 for my surrounds?
Old Jan 13, 2005 | 09:36 AM
...I guess no one else goes for the "stock look" like me...
Old Jan 13, 2005 | 10:18 AM
Cubs2k's Avatar
I kept my spare and access to it!
Old Jan 13, 2005 | 10:41 AM
SolReborn's Avatar
anyone fit an amp under their seat? my amp is about 2.5 ft long!
Old Jan 13, 2005 | 10:42 AM
SheDrivesIt's Avatar
Yeah, just no where to put the flat.
Old Jan 13, 2005 | 11:00 AM
darkknight1999's Avatar
Jeff sub is removable Quick disconnects... It a real emergency the sub box can sit on the front seat. (or the passengers lap)
Old Jan 13, 2005 | 12:12 PM
LATEOTT's Avatar
I have an Alpine 4-3-2-channel amp inside my spare tire, and an Xtant 3-channel amp in the space above the fuel tank. Two amps, completely invisible, no loss of trunk space, no loss of spare tire.
Many others have done the same.
There is also space to the left of the spare (between the spare and the fuel tank), but not much space.
One S2Ki member (Modifry) has placed an amp in the passenger footwell under the carpet (along with a 10" subwoofer) with minimal loss of legroom (between 1 and 3 inches.)
Small amps may fit under the driver seat if you do not have the OEM security system (which is bolted to the bottom of the driver's seat.)
Tiny amps (Blaupunkt used to make one...) might fit under the passenger seat, but they have to be short and narrow because of the indentation from the underfloor exhaust line.
If you want to take heroic measures, you may be able to fit something behind the driver's rollbar area, in front of the fuel tank. That space is accessible by removing the back convertible-top tray, side panel, and possibly the top and frame itself. In other words it is quite inaccessible, but it is a space, and it is available, and, well, you asked...
Good luck!
Old Jan 14, 2005 | 09:09 AM
LubedKoala's Avatar
Mount the amp(s) under the seats. You have to run more wire, but it is an option.
Old Jan 14, 2005 | 01:36 PM
Willie Gee's Avatar
plus you get seat warmers :BONUS:
Old Jan 14, 2005 | 04:27 PM
flitcroft's Avatar
Why would you drive with the spare tire? (This is a serious response). The spare doesn't fit both front and rear wheels and adds as much weight as an aftermarket audio system without subs. If you have anything at all in your trunk when you need to use your spare you're SOL anyway unless you want a filthy tire on your passenger (or seat).
Very few new sports cars have working systems for spares (and more and more are switching to 0-pressure tires). Carry Fix-A-Flat and a cell phone and knock on wood like the rest of us.
