S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Electronics (https://www.s2ki.com/forums/s2000-electronics-26/)
-   -   Amp install location (https://www.s2ki.com/forums/s2000-electronics-26/amp-install-location-398729/)
mikeyg Jun 22, 2006 07:46 AM
I'm asking around trying to see if anyone has mounted an amp over the fuel filler neck, and if so, how they have gone about doing it. I was thinkingof glassing up a tray to fit under there, but due to the tight working conditions this may or may not be feasible...
Any suggestions?
oth Jun 23, 2006 07:13 AM
I installed a Boston GT40 above the gas tank/filler neck.
http://static.flickr.com/47/173269060_4a7355a25e.jpg
The amp is mounted on 1/4" plywood cut to fit the space and
assure good airflow, and does not move a bit even though
the rack is not bolted in.
http://static.flickr.com/48/173269062_2b191c0884.jpg
Will Jun 23, 2006 05:29 PM
http://www.euroboutique.us/upload/amp%20rack.jpg
Also check this thread, right above yours:
S4Play's thread
inactiveuser1114 Dec 7, 2007 06:04 AM
Bringing this back from the dead :eek3: i doing some research into this amp install location, notice yours (oth) if your still out there and can hear me :) in all this time have you experience over heatting issues? it looks preatty tight, and you didn't remove the top tray, any feed back on this? thanks
I;ll be re doing my system soon and liked this location but just scared of getting too hot in there :confused:
oth Dec 7, 2007 06:57 AM
I've had no heat issues, but I chose this amp specifically for this space:
the heat sink is on the (left) side, and the amp has a built-in cooling fan.
Other people have apparently successfully put the JL 300/4 there, as well
as the Alpine PDX which has the advantage of being class D so it runs
much cooler.
I'll also add that I probably don't drive my amp as hard as some people
out there do, being a (relatively) old f*rt.
inactiveuser1114 Dec 7, 2007 09:53 AM
much cooler.
cool it sure those like that amp fits like a glove in that space :thumbup:
my alpine does have a cooling fan as well but i don't see any kind of vents anywhere (besides those of the fan) :confused: who knows... oh well i'll give it a shoot when i get around it maybe i can add an external fan? i have a couple of those :ponder: and see how that goes. space wise thats gots to be the best amp location on this car.
thanks for the feedback :hello:
1st07inOH Dec 7, 2007 10:21 AM
I am currently looking at this spot too. Seems like the best one I can find being I am not willing to lose my spare and I am too tall to mount any behind the seats.
DDuds2k Dec 15, 2007 09:49 AM
I have a jl 300/2 in this amps place now....
If you remove the rear tray in the back, you have plenty of room. You dont have to sandwhich the amp in there any more.
Plus I made some holes in the rack to help air flow....dont know if it works or not, but i dont have overheating issues.
https://cimg7.ibsrv.net/gimg/www.s2k...f3a3a383f5.jpg
https://cimg2.ibsrv.net/gimg/www.s2k...ade8f330ca.jpg
https://cimg1.ibsrv.net/gimg/www.s2k...069b356347.jpg
MikeyCB May 29, 2008 11:19 PM
Bringing it back from the dead...
Could anyone please give some rough measurements that I can work with to make a rack like this myself? I want to put my amp in there as well so it's plenty out of the way.
If someone could provide the roughly rectangular piece of wood that is needed to start, I'll make the necessary trims myself based on the pics I see here.
Thank you in advance!
oth May 30, 2008 06:20 AM
I made a cardboard template to test fit. basic rectangle is 19" x 16"
though in the end I think I made the rack a little longer than 19" at the
right rear to wedge it in against the spare tire. Anyway, just cut out a
piece of cardboard, stick it in, cut away wherever you need clearance
(roll bar, filler neck, gas gauge sender) until you have what you want.
© 2026 MH Sub I, LLC dba Internet Brands
