Amp Overheating?
Old Jun 5, 2008 | 01:23 PM
crav3s2k's Avatar
Default Amp Overheating?
Hey guys, I just installed a 12' kicker sub. I've noticed that my amp gets really hot after awhile and my sub stops playing after awhile. Plays and stops.
I am using 8 gauge wiring. I only have my sub wired in.
Could it be a bad ground?
Old Jun 5, 2008 | 03:21 PM
DFWs2k's Avatar
Does your amp have any room around? Circulating air?
Old Jun 5, 2008 | 03:22 PM
DFWs2k's Avatar
I don't think a bad ground would lead to overheating, it would lead more to the amp cutting out/not coming on.
Old Jun 5, 2008 | 05:04 PM
crav3s2k's Avatar
I have it laid on the ground and nothing around it.
Old Jun 5, 2008 | 05:43 PM
vspc2nr's Avatar
whats the specks on the sub?? Single or DVC?? how about the amp, is it 2ch or a Mono amp?? More info would help.
Old Jun 6, 2008 | 06:05 AM
00wreckedS's Avatar
if your ohm load is too low, the amp will have to work much harder which creates more heat, which leads to the amp shutting itself down for protection.
like ^^ above post said, whats the spec's on the sub and amp?
Old Jun 6, 2008 | 06:54 AM
WLAURENT's Avatar
Whats the amp brand and model - same for subwoofer
Old Jun 6, 2008 | 08:51 AM
crav3s2k's Avatar
My amp is 300 watt 4 channel (i forget the name of the company). I have a Kicker sub 600 watt rms 1200 watt peak.
crav3s2k's Avatar
I also used a 2 channel 600 watt amp and it was doing the same thing.
Old Jun 6, 2008 | 05:35 PM
RS2000's Avatar
Is your sub a 2ohm or 4ohm?
If 2ohm, is your amp 2ohm stable?
Are you bridging 2 channels to power the amp?
