Amp to push...Infinity Kappa Components
Old Nov 14, 2006 | 02:38 PM
SlidinS2k's Avatar
Bump for new question up top!
Old Nov 14, 2006 | 03:01 PM
NFRs2000NYC's Avatar
You are getting Kappas? Or Kappa Perfects?
Old Nov 14, 2006 | 03:05 PM
r_duff's Avatar
Kappas, 60.7 components. I'd recommend atleast a 75x2 RMS
Old Nov 14, 2006 | 03:07 PM
SlidinS2k's Avatar
^ Yes...Thanks.
Old Nov 15, 2006 | 06:27 AM
SlidinS2k's Avatar
Bump...
What brand of amps should I be looking at?
Old Nov 15, 2006 | 07:55 AM
oth's Avatar
oth
there are many good brands of amps. if you tell us
your goals, people might be able to make suitable
suggestions. for instance, are you looking for:
- low budget?
- high end?
- bling?
- hidden mounting?
- extra channel(s) for a future sub?
for me, I bought a Boston GT-40 because I could mount it hidden,
above the gas tank, but one might make a different choice if you
wanted to mount it exposed in the trunk.
Old Nov 15, 2006 | 08:28 AM
SlidinS2k's Avatar
No budget...Just want a quality amp for the Infinity Kappa's. Small in size, hidden under pass. seat/spare tire area.
I'm going to see how this sounds before I decide on a sub. If I decide on a sub, I'm going to sell this one and buy one with additional channels.
Old Nov 15, 2006 | 01:18 PM
Nugget's Avatar
I am more or less about to install this exact setup.
I have installed currently
Alpine 9857 with wired modifry dci
IPOD fast connect cable
Will be installing this winter,
Wlaurent trunk well sub box with Elemental deisgn 10in
Kappa Perfect 6.1 components
I have a 4 channel JBL amp to power everything.
I definitely would not recommend running it off the headunit, but I think you got that. You can buy a 2 channel for the kappas with about 100x2 RMS should be plenty and then if you want a sub get a mono amp that pushes 200-300 watts rms
Look at the reference infinity amps, they are inexpensive and should work well. JBL are fine, alpine will work fine. Just becareful where you buy. Make sure they are a rep.
Good luck.
Old Nov 15, 2006 | 02:16 PM
SlidinS2k's Avatar
What about Hifonics?
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=13986
This amp's specs match up with the Kappa's.
Kappa components
Rms power range- 2x90 W
Peak- 270 W
Falcon amp
2x90 W
280 W
Old Nov 15, 2006 | 02:33 PM
RBR's Avatar
RBR
Alpine PDX 4.150
4 x 150w. use 2 channels for your components, the other 2 for your sub. tiny amp so will be easy to install.
