Amp to push...Infinity Kappa Components
Old Nov 15, 2006 | 02:59 PM
  #21
hahnn002's Avatar
Check out what Alphasonik has to offer. If you find one you like Kinetic (darkknight1999) has some amazing prices on those amps. I'm going to use their 5-channel PMA5753A: 75 Watts x 4 @ 4Ω Stereo and & 260 Watts x 1 @ 4Ω Mono. I have Infinity Perfect 6.1 components in the doors, Infinity Reference 5010 components to go in S-pods, and an Infinity 10.1 sub to go in the tool well. I was going to to with the Alpine PDX amps to match my Alpine head unit, but couldn't find a deal on them like I did the Alphasonik.
Old Nov 15, 2006 | 03:06 PM
  #22
hahnn002's Avatar
Also, under-powering speakers too far can be as bad as giving them too much power. Some good articles on Crutchfield about that topic.
Old Nov 15, 2006 | 03:24 PM
  #23
SlidinS2k's Avatar
I pm'd him a week or so ago about the sub box group buy and haven't got a reply yet.
Old Nov 15, 2006 | 03:32 PM
  #24
hahnn002's Avatar
Maybe try again? I pm'd him yesterday and had 3 replies today.
Old Nov 15, 2006 | 03:34 PM
  #25
SlidinS2k's Avatar
Old Nov 19, 2006 | 01:33 PM
  #26
SlidinS2k's Avatar
I searched and read the F&Q....I have a few more questions...
Help me visualize.
For installing a new HU, amp, wires and components.
A power wire runs from the battery to the amp.
Speaker wire runs from the amp to the speakers.
Rca wire runs from the HU to the amp.
Correct?
Would there be any reason for me to avoid running the power wire in the center console area? (where some run speaker wires)
Can I run the rca wire w/ the power wire?
How much clearance is under the passenger seat? (where I want the amp)
Thanks.
Old Nov 19, 2006 | 07:05 PM
  #27
oth's Avatar
oth
Yes, you're right about which wires go to/from which component.
You want to separate the amp power wire from the RCAs and speaker wires
because the high current can induce noise in those signal-carrying wires.
You can run the RCAs and speaker wires together, though, as long as
you use good quality (well-shielded) RCAs.
Even if you're running the RCAs & speaker wires elsewhere, I wouldn't
run the amp power wire down the center console because:
a) there's no good reason to - it's not the most direct path
b) you'll be bringing it right by the headunit and can induce noise there.
Old Nov 19, 2006 | 08:18 PM
  #28
SlidinS2k's Avatar
Thanks for the reply!!!
Old Nov 28, 2006 | 03:02 AM
  #29
SlidinS2k's Avatar
Originally Posted by r_duff,Nov 14 2006, 06:05 PM
Kappas, 60.7 components. I'd recommend atleast a 75x2 RMS
What would be a maximum recommendation...I don't want to blow those bastards up.
Old Nov 28, 2006 | 08:27 AM
  #30
hahnn002's Avatar
Specifications
MSRP U.S. $: 349.95
Power Handling, RMS: 90 Watts
Power Handling, Peak: 270 Watts
Sensitivity: 95dB
Frequency Response: 45Hz - 25kHz
Mounting Depth: 2-3/16"
Impedance: 2 Ohms
http://www.infinitysystems.com/caraudio/pr...Ser=KAP&Cat=COS
