Amp wiring help!
Old Oct 18, 2009 | 01:23 PM
ybadic's Avatar
Originally Posted by GrandMasterKhan,Oct 13 2009, 11:18 PM
using the proper size is ideal. Running larger gauge is optional. 1 guage will probably be overkill and just make running the wires through the car that much harder.
Old Oct 19, 2009 | 10:54 PM
Claus's Avatar
4 gauge
knukoncept
run active setup instead of bridging.
Old Oct 22, 2009 | 06:52 AM
Neutered Sputniks's Avatar
Originally Posted by Claus,Oct 20 2009, 02:54 AM
4 gauge
knukoncept
Of course, that requires quality speakers (not Alpine/JL/MB Quart/etc).
Old Oct 22, 2009 | 09:39 AM
VTEC 2 NV's Avatar
Originally Posted by Claus,Oct 19 2009, 10:54 PM
4 gauge
knukoncept
Wait what's the difference between active setup and bridging?
Old Oct 22, 2009 | 10:06 AM
VTEC 2 NV's Avatar
Damn I had thought alpine were good quality speakers, what are good quality speakers that we can fit into our doors?
Old Oct 22, 2009 | 10:23 AM
Well, if you're going to run Active...there are a number of selections that will work for you in a similar price range.
What, exactly, is your price range (if you don't mind me asking)?
Old Oct 22, 2009 | 10:57 AM
VTEC 2 NV's Avatar
Well I really don't know which is better bridging or active I don't know about this kind of stuff(I'm buying the parts someone else will do the install for me that's why I wanna learn) as for spending limit I don't really have a limit as long as it is compatible with my amp so I don't have to go buy another amp. I just don't know about brands or quality speakers I always thought alpine was good
Old Oct 22, 2009 | 11:37 AM
A properly tuned Active system will sound much better than bridging your amp to a Passive system.
A passive system has 2 speakers per output channel of your amp (i.e. bridging your amp makes 2 output channels, rather than 4).
An active system has 1 speaker per output channel of the amp, with nothing between the amp and the speaker. This allows the amp to directly impact the performance of the speaker, rather than sending the audio signal to a passive xover which, to some extent, isolates the speaker from direct amplifier control.
In other words, an active system gives your amp more control over each speaker.
There are other benefits, but this is the primary one.
Old Oct 22, 2009 | 12:24 PM
VTEC 2 NV's Avatar
Can I do that with the alpine type R speakers or is that for quality speakers? What are good quality speakers I can run with same amp?
Old Oct 26, 2009 | 11:26 AM
hellspare's Avatar
Are you referring to using crossover(s) and not? I thought each channel on the amp is for 1 speaker. So if you had a 2 channel amp it would be hooked up to 2 speakers, 1 for each channel.
