Amps won't come on...
Old Apr 3, 2006 | 12:52 PM
REvan's Avatar
Default Amps won't come on...
Lunch break, stereo played as usual. Get in car to drive home and nothing...
I have 2 amps and neither will turn on. Head unit is working as normal. I checked the wiring in back of head unit and going into amps and everything looks good. Also checked the fuses and didnt see one blown, but that has got to be it...
Anyone have any suggestions?
Old Apr 3, 2006 | 01:15 PM
littlerocket777's Avatar
Amp not coming has 4 causes. Loose power, loose gound, loose remote or blown fuse. Did you check amp fuse and wire fuse?
Old Apr 4, 2006 | 09:33 AM
REvan's Avatar
Found the problem last night. It was the main fuse coming off the power line hooked to the battery. It looked fine, but i guess from heat and age had cracked inside and failed. Thanks for helping!
Old Apr 4, 2006 | 10:20 AM
00S2K01S4's Avatar
^ has happened to me before.
Old Apr 5, 2006 | 05:03 AM
REvan's Avatar
Apparently this happens a lot. i checked everything and found nothing and had to go to stereo shop and pay $27 and it was the first thing the guy checked. Oh well, at least it works now...
LubedKoala
May 12, 2008 12:40 PM
droo587
Mar 16, 2008 09:50 PM
Brennon
Oct 3, 2006 09:01 PM
Stu A.
Aug 9, 2006 07:03 PM
Goldtrom
Jul 23, 2001 02:30 PM
