Antenna Assembly substitute?
Old Apr 22, 2013 | 06:17 PM
ajzerick's Avatar
Default Antenna Assembly substitute?
Sup guys, question. I bought my AP1 about a month ago, and it sounds great and all, but I have a few problems.
1) I have the iSimple hookup (previous owner) but I think the wire has a short (only plays one speaker if wire is bent the most precise angle), so it charges no problem, but no music half the time :/
2) My antenna is broken off, and it seems the top part where you screw on is broken off. I'm not getting any signal at all on any station.
So my questions are:
- Can I just replace the cord (I have no idea how it's hooked up) to iSimple and it probably work?
- Can I block off the antenna hole and just get some sort of device/mechanism to still get signal? I really don't want to pay $120+ for an assembly
Thanks guys!
Old Apr 23, 2013 | 07:09 AM
oth's Avatar
oth
The antenna is amplified, which is why the assembly is so expensive. That said, the
assembly is made up of a bunch of different parts, and depending on what is broken
you may be able to get away with only replacing some relatively inexpensive parts.
Old Apr 23, 2013 | 02:48 PM
AP1Drew's Avatar
If you need just the antenna element (the black part that sticks up), the Acura RDX antennas fit right on and are much cheaper(mine kept getting stolen). p/n 39151-STK-A01. msrp only $10!
Old Apr 24, 2013 | 01:05 PM
ajzerick's Avatar
Thanks guys - I have a friend with an AP1 and I plan to see if attaching his antenna (if I can get it on somehow) will fit. Part 7 is the part that appears broken.
Old Apr 24, 2013 | 02:22 PM
oth's Avatar
oth
if you click on that hondaautomotiveparts.com link, you'll find that #7 is a $4 part
vanzant54
Jun 8, 2011 02:03 PM
StormTroopinAP2
Jun 25, 2010 06:31 PM
dr.s2k
Apr 26, 2010 08:44 AM
w00tw00t111
Apr 9, 2008 07:32 AM
DaveZ
Jun 11, 2002 07:20 PM
