Baffles for front speakers?
Is anyone using these? I have notived a very good bass response without them but lucid claims they will improve bass response just looking for feedback.
However, I still use them for moisture protection. I just cut out a hole in the bottom of 'em to let the air pass through.
JawKnee...I believe these are what he's refering to:
I also assumed he was referring to the XTC Baffles or something similar.
I also run these as well, and as Dcon67 already mentioned, these will actually hurt bass response since most components aren't designed to be used in a sealed application. I actually tested the bass response without the baffle and with an unmodified baffle, and the bass response was definitely hurt due to the baffle.
However, again like Dcon67, I use them for moisture protection, but I cut more than just a hole in the bottom. I essentially cut the back so it would act as an umbrella if that makes any sense.
