Best grounding point?
Old Jun 22, 2005 | 03:03 PM
DaPutster's Avatar
Default Best grounding point?
I bought this grounding terminal for the 1/0 setup I'm installing, but I'm not quite sure where the best place to mount this thing in the engine compartment. Since it doesn't use any existing bolt setup, is it just a matter of grinding down to metal in the spot where I want to mount it? Would it be best to do this just to the right or left of the current grounding point? Here is a pic of the terminal :http://images.cardomain.net/products/str/STRGT0.jpg
TIA
Old Jun 22, 2005 | 03:06 PM
dbzerk's Avatar
NICE!
As long as you ground it around the same area as the original ground you should be ok.. Like you said make sure you get all the paint off before you install it..
Old Jun 22, 2005 | 09:29 PM
MR_ASDF's Avatar
Spammer
some part of the frame/chassis or a place with double sheet metal.
Old Jun 23, 2005 | 12:04 AM
DaPutster's Avatar
Worked like a charm, thanks guys. I'll post pics with the system once I finish getting everything else installed.
Black_eS
San Diego S2000 Owners
Jan 11, 2011 08:55 PM
enoyskt
Apr 29, 2010 10:38 PM
turbo_pwr
Jan 8, 2010 12:47 PM
hyperpm
Mar 20, 2008 10:14 PM
