Big THANKS to Electronics forum
Old Aug 26, 2005 | 10:54 AM
koala's Avatar
Thanks so much for the suggestions. Now you really are leading me to believe I wasn't looking through the head unit settings enough.
I'll hopefully get to try this again tonight or tomorrow night
Old Aug 26, 2005 | 12:17 PM
PJK3's Avatar
k. i'll try to check the site during the weekend to look for status updates.
Old Aug 26, 2005 | 08:27 PM
koala's Avatar
You're going to laugh at me when I tell you this:
I had the RCA's hooked up to the wrong spot on the amp. The weird thing is that I had them hooked into the spot labelled "input." So sure enough I hooked them up to the "output" label and everything worked! Very strange because I would have assumed "input" was the correct one
Thanks for all of your help!
Old Aug 27, 2005 | 01:22 AM
kw2000's Avatar
Id like to thank the Electronic Forum also. I also installed my Alpine HU, Polk Momo Speakers, and Amp. I found myself running back and forth from my car to the forum to read where to run wires and such. But I have ran into One problem.
With my Driver's side Speaker when i have it bolted down all the way its making contact with something, causing it to cut out. Ive look at everything, I can't seem to figure out whats causing the speaker to cut out. All the speaker wire is secure. Ive noticed that when I have the top 2 Bolts screwed in, it works fine but once I push or bolt in the bottom 2 it cuts out. Anyone had this problem? or should i jsut buy a speaker baffle and call it good?
Old Aug 27, 2005 | 08:25 AM
jwa4378's Avatar
I would make sure the positive teminal is not contacting any metal, or that the wire is not over-stripped. This would cause the signal to go directly to ground. Make sure the connections are good to the speaker. Sometimes the wires are a bit too short, and get pulled off to a bad connection when fulled pushed back.
Dont feel bad....I did the same thing....except I pugged mine into the rear output instead of the subwoofer output. Things happen when you are tired and want to get it done with!
John
Old Aug 27, 2005 | 08:31 AM
koala's Avatar
Did you use the foam "rings" that came with your polk speakers? I found that on mine, if I didn't use the foam rings, the speaker was being "forced" into the speaker basket too much. With that extra spacer in there, it fit like a glove.
Old Aug 27, 2005 | 12:12 PM
PJK3's Avatar
laugh?
ha.... it's been done before.
i would have assumed input was correct too. how odd.
regarding the other door question?
and using the foam rings is a good idea both for spacing AND to help seal the speaker and prevent any additional noise from air leaks.
Old Aug 27, 2005 | 02:58 PM
WLAURENT's Avatar
Actually either terminal (pos or neg) will cause problems if it touches ground.
rtboy10
Aug 31, 2015 04:47 PM
Disgustipated
Socal Swap Meet
May 17, 2010 02:28 AM
owenxguo
Oct 12, 2004 09:24 PM
DarthPaulUK
Sep 21, 2004 01:07 PM
rocketman
Sep 5, 2001 08:57 AM
