blinker and emergencies not working after install
Old Nov 16, 2008 | 01:21 PM
wsspencer0623's Avatar
Default blinker and emergencies not working after install
My apologies but I am not mechanical in anyway I really need help though. I am female if that excuses it.... :}
I recently took my 2006 s2000 into a stereo place to have an I pod hookup and a satelite tuner hooked to my factory radio. As soon as I left the store it did not work. I took it back in and they called Honda and told me that hooking up both was causing a conflict. So I chose the satellite tuner so they took out the i pod connection. Two days later I noticed my blinkers weren't working. I had the fuses checked and that was not the problem. Now I have to take the car back into the stereo store and ask them to look at the blinker problem. Any input on how to deal with the stereo shop or possibly Honda. It's still under warranty but from what I am reading I probably messed that up by having someone install to my factory radio. Thanks for your time.
Old Nov 16, 2008 | 01:31 PM
ahrmike's Avatar
If they did a shitty job, they might have crossed some wires, but I dont see how the radio should affect the blinkers...
Old Nov 16, 2008 | 02:05 PM
thrillissues's Avatar
Do your turn signals work or is this limited only to your emergency flasher button?
Old Nov 16, 2008 | 02:07 PM
Both the turn signals and the emergency flasher are not working.
Old Nov 16, 2008 | 02:16 PM
Abide's Avatar
sounds like they forgot to plug the hazard switch back in, pop your armrest up and plug it back. I've forgotten to do it quite a few times.
Old Nov 16, 2008 | 02:40 PM
Thanks! I will have someone help me to see if this is the case.
Old Nov 16, 2008 | 03:14 PM
Abide's Avatar
it's really cake, you shouldnt need help. Prolly take 30 seconds, just pull up on the back by the glovebox and keep prying up with your fingers. you shouldnt need to remove the shiftknob or anything just tilt it to the side and check that it's plugged in.
Old Nov 17, 2008 | 04:41 PM
Thanks very much. That was the case. Actually, three things were unplugged: blinkers, emergency, and roof were all left unplugged. Plugged them back in and everything works. Thank you!
Old Nov 17, 2008 | 05:28 PM
Abide's Avatar
yep yep, if you get to messing around in that area yourself, trust me youll do it about 10 more times. Eventually youll get good enough to plug it back in at a stoplight! ha ha!
Old Nov 18, 2008 | 07:28 AM
martin j's Avatar
Nice easy result, aint this place good.
honda two thousand
Mar 11, 2018 11:35 AM
GeoffMM
Aug 5, 2007 04:39 PM
BUDRISS
Jan 8, 2007 10:42 PM
S2kNY
Jul 31, 2006 12:05 PM
