Building a custom digital clock
Old Apr 3, 2006 | 08:30 AM
ideugene's Avatar
Default Building a custom digital clock
I am in need of a custom clock for the S. I was looking around and found this website:
http://www.iguanalabs.com/mbklcd.htm
http://www.iguanalabs.com/mbkit.htm
They have basic kits that will teach the fundamentals of electronics and microprocessor programming. With this and a custom LCD display such as this one: http://www.crystalfontz.com/products/1602b...#CFAH1602BTMCJP
Is it possible to build myself a clock with the date? Expensive? I know, but I wish to learn in the process. The LCD Module is a 16-pin display similar to the one in the kit. After I get good maybe I can add temperature to the display as well.
EJ's help!
Old Apr 3, 2006 | 10:18 AM
SweART's Avatar
Well. Microcontroller projects are fun. Personally I think the display you have chosen might be a little bit overkill.
I would go for something along the lines of http://chaokhun.kmitl.ac.th/~kswichit/Ajay/clock.html
Have fun!
Old Apr 3, 2006 | 10:53 PM
ideugene's Avatar
My entire car is overkill. Anyone know if that screen will work with those microprocessor products?
Old Apr 3, 2006 | 11:29 PM
Tony Yeung's Avatar
OR..............you can get a digi watch and tape it to the dash hehe
Yea, its quite annoying not having a clock in the car, i never know what time it is and im forced to dig in my pockets when driving.
Goodluck with the digi clock!
Old Apr 4, 2006 | 03:46 AM
SweART's Avatar
Read the datasheets. The one for the display was quite informative.
2051 is not a uC I am familliar with and I am more lazy than curious today, so...
Besides, you should read those datasheets anyway -- if you understand them you know you have a reasonable chance of completing this project.
Old Apr 4, 2006 | 07:19 AM
ideugene's Avatar
Haha quite true but I have yet to purchase the beginner's kit to start learning about all of this. I just need to know if it can be done with the products mentioned so I can buy it and start learning!
Old Apr 4, 2006 | 07:34 AM
cliffdogg2k's Avatar
get an aftermarket head unit that has a clock on it. i used to be annoyed when i had to look for my cell while driving to see how i was doing on time. but with a head unit the problem is solved!
Old Apr 4, 2006 | 07:53 AM
ideugene's Avatar
I do have an aftermarket unit. However, its still annoying to switch between song info and time. In addition, I need a filler for my dash cutting project and this is the perfect size.
Old Apr 4, 2006 | 08:26 AM
ah well in that case take lots of pics of the install! =)
Old Apr 4, 2006 | 11:58 AM
SweART's Avatar
Well. A quick look then...
Assuming we are talking about the AT89C2051 uC (www.atmel.com/atmel/acrobat/doc0368.pdf) a quick look would indicate that it has an I/O port that *should* be possible to use for communication with the display. However, while it does have timers I cannot see an RTC on the block diagram (nor mentioned in the text). I think you would want that for your app, and since many uC's do have one choosing another might be a good idea.
I have no recomendation (been away from HW design for a while and things develop so very fast...) Google is your friend, however.
