can someone help me with crossover setting
http://vault.alpine-usa.com/products/docum...OM_SPX-177R.PDF
If you could take a look at page 21-23 it shows 9 different jumper settings for the croosover. I'm trying to get more midrange and am not sure what would be the best setting. Thanks!
"Note: Network simulations above illustrate the effect of each filter upon the input signal, not the actual summed frequency response of the speaker system. Tweeter response curves represent the different level settings available."
the info on 21-23 is not going to too helpful. I'd probably just set it up per the instructions on 15-16 and adjust it with equalization....
15 - 18 are phase correction between the mid bass and tweeters, they must be set according to the instruction to take the bull benefit of the speakers.
I haven't played with the SPX-177R yet, but Set 5 for crossover frequency should work for you.
S2000boi
Jan 3, 2003 09:43 AM
