change headlight bulbs
Old Jan 1, 2009 | 07:15 AM
boiii4's Avatar
Default change headlight bulbs
how to change the headlight bulbs? any ideas? thanks
Old Jan 1, 2009 | 12:33 PM
s2k aok's Avatar
surprisingly i haven't had to change out the bulbs yet...
Old Jan 1, 2009 | 05:39 PM
dezymond's Avatar
haven't attempted to change my bulbs yet, but i have on my other cars.
the only thing different for the S, i think you have to remove the front bumper to get to the headlights, could be wrong.I did read about it somewhere on this forum, search it.
Old Jan 1, 2009 | 09:30 PM
Neutered Sputniks's Avatar
^^You're doing it wrong...
You should be able to reach behind the headlights through holes in the engine compartment...
Old Jan 2, 2009 | 06:59 AM
boiii4's Avatar
dont you have to unscrew the something or just turn the socket?
Old Jan 2, 2009 | 03:37 PM
dezymond's Avatar
like i said i never changed my bulbs in the S yet. In my other cars i know it's just a simple twist of the bulb, pop-out , and replace.
when i was reading about changing the bulbs in the S, i kept reading that the front bumper had to be removed.
i am thinking of getting 5000k or 6000k bulbs though, anyone got any good prices?
Old Jan 2, 2009 | 05:54 PM
S2Sloww's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry10955288
Aka Stopmenot2002
Old Jan 3, 2009 | 08:24 AM
mr_grand_prix's Avatar
You do have to remove your front bumper or try to go through the fender liner..
you will need a 25m torx to unscrew the bolt to replace the HID bulb.
I would uninstall the front bumper to be safe and to prevent you from not seeing what u are doing. Its time consuming but very easy.
Hope this helps.
Old Jan 4, 2009 | 06:11 PM
Hope this helps.
Funny...I managed to replace both turn signal bulbs without removing the bumper or liner. I'd imagine that since the turn signals are further into the fender than the headlights I could change the headlight bulbs without removing the bumper or liner. Oh well, what do I know, I've been wrong before
Old Jan 28, 2010 | 09:42 PM
marksae's Avatar
I just changed my headlight bulbs. The security screw is a T25 Torx tamperproof screw. So I didn't have a short bit of that size. All I had was a screwdriver, so it was too long to stick into access hole from the engine compartment.
I ended up taking off my front wheels and pulling back the fender liners to access the bulbs. It wasn't that bad. Just a bit tedious removing all those clips and bolts. But the end result was worth it. 6000K bulbs look much better than the OEM 4300K.
