cheeze with that alternator whine?
Originally posted by PJK3
if you think about pursuing this route, we can go into more details later, but be aware that balanced cable and converters don't always come cheap.
i tried a ground look iso, and it didn't help. i'm not a big fan of that since you should really solve your grounding problem by using a proper ground (and solving your ground loop problem) instead of using a band-aid.
PJK3, i've heard good things about adcom, it really is a shame they don't make car amps anymore (well not that big, since they were so expensive). Oh and fyi, i've read that the current kicker kx amps are still a little under-rated, the 400 one (100X4) seems to test out in the 500 range (4X125). which explains why they give up about 5 inches to similiarly (published) rated amps.
this would be especially true if you ran balanced cables from the headunit all the way to the amp (~10ft) that would be a really expensive cable since balanced ones seem to come in short lengths.
i just googled up this site and these items to give you some pricing ideas - i've no clue as to reputation of the vendor, etc.
20' balanced XLR cable
femal XLR to female RCA adapter
male XLR to female RCA adapter
just as an fyi - i've never tried doing this personally in a vehicle, so i'm mostly just shooting from the hip based upon what i've done in other arenas. if you're serious about doing this, i'll get some gear together and run a test to see how well XLR mic cable will carry a pre-amp signal over 20', before you buy anything. either that, or keep your receipt. it SHOULD work... lol.
yeah, i love my Adcom amp... i purchased it via a super good deal... it's got a super sweet sound and in the manual it states it to be stable down to .5 ohm loads. i really don't use it to it's full extent.
thanks for the info on the KX series... even if they aren't mono-stable below 4 ohms, it's good to hear that at least they are under rated.
btw, while i was checking on some cabling things for you, i just happened to see Crutchfield closing out a bunch of Kicker ZX-460 amps for $199 - they are rated at 4 x 30watt, but could probably be expected to do a little better (given Kicker's apparent tendancy to under-rate their stuff)
