Cigarette lighter blows fuse when using a tire inflator..
Old Apr 23, 2012 | 07:16 AM
SlowTeg's Avatar
Default Cigarette lighter blows fuse when using a tire inflator..
Just like the topic says, whenever I plug a tire inflator into my cigarette lighter, it inevitably blows a fuse. I realize now that I should probably start the car when using the inflator (so it runs at a higher voltage and perhaps draws less amps), but still, is it just a problem of the circuit being too weak to handle anything drawing more than a few amps? I don't have any issue with cell phone chargers, but tire inflators seem to blow the 10amp fuse pretty easily.
I'm a little confused on the electrical wiring in the car. The same circuit powers the headunit and the cigarette lighter? Or is the cigarette lighter circuit just used to trigger the headunit on/off? It's pretty irritating to say the least.. Thanks for any help.
Old Apr 23, 2012 | 11:48 AM
aphex4000's Avatar
Yes, the same fuse protects both the audio and 12v outlet. Sounds like the same problem here. I keep one of these along with the tire inflator.
http://www.amazon.com/Custom-Accesso.../dp/B000CMJW46
Old Apr 23, 2012 | 01:50 PM
SlowTeg's Avatar
Aphex, Thanks for those links!
I guess I understand why people install that second cigarette lighter in the car, as the main one is so weak. I think I'll probably just pick up that battery adapter, that'll certainly do the trick should I need to use a tire inflator.
Old Apr 24, 2012 | 04:47 AM
takeshi's Avatar
Doesn't really help the OP but I use one that has battery clamps.
batguano
Dec 18, 2010 07:55 AM
XclusiveAutosports
Oct 20, 2009 08:36 PM
mosmmc
Oct 4, 2009 09:50 AM
Janan
Jan 4, 2009 10:04 PM
charlie
Apr 4, 2001 09:01 AM
