Clear headlights for S2000
Old Aug 31, 2001 | 05:41 AM
Rick7's Avatar
Default Clear headlights for S2000
I purchased a set of clear S2000 headlights. I have a problem with turn signal socket fitting into the socket hole in the back of the clear headlights. The hole in the back of the clear headlights is to big for the factory turn signal socket . Is there another larger socket available that will work? All the other sockets fit. The only socket that doesn't fit is the upper turn signal. Has anyone else had the same problem? Any help would be greatly appreciated. Thanks
Rick
Old Aug 31, 2001 | 08:41 AM
shaner's Avatar
There are definitely numerous threads on clear headlight housing mountings on US-spec cars...
I used a hole-saw to cut out the smaller mounting hole from my US spec housings and epoxy-ed them into the larger European-spec holes... If you don't want to sacrifice a set of housings (I had a bunch of extras so it didn't matter) and want it to be similar: buy/find a small/thin piece of plastic and cut the pattern out with a Dremel... glue that into the larger hole...
Just out of curiosity, what are you doing to aim them?
Old Aug 31, 2001 | 09:20 AM
Rick7's Avatar
Thank you.. I didn't have any problem aiming them the headlights. Waht exactly are they doing. I can check with my service department to see if they can help you. Can you be more specific?
sql2
May 13, 2011 08:49 PM
s2ktrippin
Nov 22, 2008 08:11 AM
krazyjon
Mar 1, 2004 08:47 AM
Rick7
Aug 31, 2001 11:29 AM
Rick7
Aug 31, 2001 09:24 AM
