Clicking noise from speaker
Old Jan 21, 2011 | 03:33 PM
enginestoppy's Avatar
Default Clicking noise from speaker
I've recently noticed a "clicking" noise from my passenger-side speaker when the car is on. This really started after the audio shop that installed my system (deck/components/amp/sub) relocated the crossovers under the dash. I do also get a bit of engine noise in the lines.
The shop is pretty busy as am I so I can't take it in any time soon. I thought maybe I can resolve the issue myself.
I saw that one crossover is in the kickpanel area on the passenger side. Is the power cable too close to it causing interfere?
Here's a pic:
Thanks much!
Old Jan 21, 2011 | 04:25 PM
DFWs2k's Avatar
Probably, why'd you have then relocated
Old Jan 21, 2011 | 05:03 PM
TestMonkey's Avatar
Mine was making a clicking noise as well, but only when I switched radio stations or switched the source. I figured out that a fuse in my amp was blown. Not sure if your having the same problem but might be a fuse.
Old Jan 21, 2011 | 06:09 PM
JunD's Avatar
The power cable could be causing the problem.
My question is....why do you have 3 different types of speaker wire?
JunD
Dec 3, 2010 11:33 AM
watchdogd
Oct 14, 2009 05:09 PM
bbak11010
Feb 6, 2009 06:02 AM
2001e46
Sep 29, 2006 05:09 PM
Lunacy
Mar 2, 2004 01:35 PM
