Cluster Display
Just a simple question: The backlight of my gauge cluster lcd is very light and is hard to see and it does not fully light up when I rev the engine past seven thousand rpm. If I get it fixed do I have to simply buy bulbs for the light? or do I have to replace the whole LCD gauge cluster. Also my roof backlight does not light up at all either.
The gauge cluster takes 2 different types of bulbs. It can be replaced with a LED bulb but you may have dead spots. For an 04 AP2, the following are the bulbs you would need to replace everything:
Tach: #74 bulb with twist lock base (some places call it T1.5 bulb). Qty 5
Blinkers: #74 bulb with twist lock base. Qty 2
Speedometer: T6.5 bulb (slightly bigger than #74 bulb) with twist lock base. Qty 2
5 #74 bulbs with twist lock bases for ABS and stuff.
10 #74 bulbs with twist lock bases for the bottom row maintenance lights.
Audio Control: 3mm NeoWedge bulbs. Qty 5
Climate Control: 4mm NeoWedge bulbs: Qty 4
Cruise Control: 3mm NeoWedge bulbs: Qty 2
Defrost button: 3mm NeoWedge bulbs: Qty 2
Starter button: 3mm NeoWedge bulbs: Qty 1
Roof button: 3mm NeoWedge bulbs: Qty 1
Emergency button: 3mm NeoWedge bulbs: Qty 1
You will not be able to get the climate and audio controls the same brightness. The controls are made differently and there isn't a bulb made that will work. Climate control always ends up dimmer.
You can order the bulbs from superbrightleds.com or autolumination.com.
Hope that helps you out.
They are sensors. I believe the Tach is located on the block.
The Gas Gauge is a sending unit located in the gas tank.
Enging Temp is also located on the block
Speedometer is located on the tranny, and along with the odometer too i believe.
What is the trip meter? same as odometer? if so then should be located on the tranny
hope this helps.
electronic gadgets-buy electronics
Car Diagnostic Tools-CarECU
hope this helps.
