connecting 2ohm sub
Old Feb 24, 2007 | 09:18 PM
hoangcs's Avatar
Default connecting 2ohm sub
i have a pdx1.1000 amp and a type x sub wired at 2 ohms. is there a special way of connecting it. i see 2 speaker outputs on the amp. do i just connect it one of them ?
Old Feb 24, 2007 | 09:43 PM
PAS2KNut's Avatar
As long as you are sure it's wired for 2ohms then just connect the + wire to speaker output channel 1 + and - wire to the speaker output channel 1 - and you should be good to go.
Old Feb 25, 2007 | 12:38 AM
hoangcs's Avatar
what the consequenses if i'm not sure and i run it at 2ohm when its not. I'm pretty sure its wired for 2ohms cause its a 2 ohm speaker right?i had a box made for the sub from al and eds and i told him what amp i had. so i think its 2 ohms. i want to run it now cause i just wired my amp.
Old Feb 25, 2007 | 12:43 AM
hoangcs's Avatar
also i dont understand your reply.
heres a pic of the back of my amp
http://www.crutchfield.com/S-K4ZWsCxfofG/c...&display=XL#Tab
could you be a little more specific please. thank you.
Old Feb 25, 2007 | 01:48 AM
hoangcs's Avatar
also its a mono amp 1000x1 . why is there 2 out puts?
Old Feb 25, 2007 | 04:53 AM
Cubs2k's Avatar
In case you are using a dual coil Sub....or 2 different subs you want to run in parallel.
from Crutchfield:
"The two speaker terminals are shorted together, so if you're only using one sub you can connect to either terminal."
If your are running a Type-X Sub, it probably has 2, 4 Ohm voice coils which are currently wired in parrallel.
Do what PAS2KNUT said...OR assuming I got your type X model configuration correct, run a pair of lines from each amp output to each voice coil.......
Please inclue all model numbers of equipment when asking for help.....thanks!
Old Feb 25, 2007 | 04:54 AM
darkknight1999's Avatar
You should read the manual that came with the amp. The answer is right in there. On page 2 all the way at the bottom (Fig #11) you can see in the picture that you should be connecting to the left side.
Old Feb 25, 2007 | 04:57 AM
Cubs2k's Avatar
More specifically, it is one output with multiple connectors.
Old Feb 25, 2007 | 01:31 PM
Cubs2k's Avatar
Do you have some kind of reading problem? Your question was answered......
another thread?
https://www.s2ki.com/forums/index.php?showtopic=465711
All the X-type subs I've seen are dual VC, 4ohm each......wire the VCs in parallel (+ to + and - to -) and connect them to the amp exactly like Jim said:
"just connect the + wire to speaker output channel 1 + and - wire to the speaker output channel 1 - and you should be good to go. "
or John as said to use the left one.....
Old Feb 25, 2007 | 04:16 PM
PAS2KNut's Avatar
The amp should have come with a connector that you connect the speaker wires to. On the connector there are two places to put speaker wires. One is positive (+) and one is negative (-). Take the positive (+) wire from the sub and connect it to the positive (+) position on the connector. Then take the negative (-) wire from the sub and connect it to the negative position on the connector. Once you have the sub connected to the connector plug the connector into channel 1 or the left side. Here is a picture from the manual of the PDX1000.1 showing what I just described.
What model x-series sub did you buy so I can look up the wiring diagram for 2ohms.
If you are not comfortable with these directions I highly recommend you pay someone to do this for you.
