CR gauge cluster in ap1
Old Jan 23, 2013 | 12:11 AM
allaboutdaz's Avatar
Default CR gauge cluster in ap1
Anyone have information on what needed to install CR gauge cluster in Ap1?
Old Jan 23, 2013 | 11:56 AM
apage's Avatar
I have not heard of anyone putting a CR cluster in an AP1. I know of people that have installed a CR cluster in the base 08-09 model with no problem. I believe that the mounting brackets are interchangeable from AP1 to CR, but the connectors/wiring harnesses are completely different. I would look for the connector schematic in the s2000 service manual and see if you can match an AP1 harness to the CR cluster connectors. This project will involve a great deal of custom wiring. Furthermore, there are several difference between the AP1 and CR models (VSA and TPMS to name a few) which might make the CR cluster incompatible. Good luck and let us know if you get it working.
Old Jan 23, 2013 | 12:50 PM
liquid_helix136's Avatar
Do you have an F22 in the car? Otherwise that would be annoying not knowing what rpm your at above 8k
Old Jan 23, 2013 | 01:12 PM
yeah I see ... the plug are different for sure ... I just want to know if I can use the ap2 05 dash harness for this or the 08 CR dash harness to make this work anyone ?
Old Jan 23, 2013 | 01:13 PM
Ap2 swap will be going in as well
Old Feb 27, 2013 | 12:15 AM
Anyone else have any more information?
Old Mar 1, 2013 | 10:36 PM
Stealth_SUX_'s Avatar
Dont forget from what I remember, milage is stored in the cluster. so swapping clusters gives you a different milage.
Old Mar 2, 2013 | 08:13 AM
apage's Avatar
I would ask Leester01. He is probably the most familiar with cluster swaps on this forum. I just realized that he swapped the CR cluster into an 06-07. He might be able to give you some tips on swapping it into an AP1.
Old Mar 3, 2013 | 08:35 PM
iDashX's Avatar
I had an AP2 cluster swapped into my AP1. it was a pain. Harness is different and correct, the mileage is stored on the cluster. you will have an issue if you are going to 9K as the cluster will start blinking once it is past the 8K limit. Cluster speed may be off by +/-2mph. It is also really hard to find a pin out of the cluster. you may want to purchase an entire AP2 CR dash harness to complete this. I do not know if the other end is the same as an AP1 though. I do have an 04/05 dash harness for sale if you swap to a 04/05 cluster.
Old Mar 3, 2013 | 09:04 PM
iDashX's Avatar
Originally Posted by Alpha-Male
The AP1 and AP2 cluster harnesses are interchangable?
no they are not. you need pigtails to make them fit. and would need to cut and splice the ap2 pigtails in.
